Old 09-22-2012, 09:41 PM   #1
carl.net
TT hit by a trash truck
I showed up to check out my TT at the storage yard last week, and a 50,000# trash truck had whacked my TT. Amazingly not that much was wrong except for the (looking at the TT from the front) left front vertical edge about half way up the trailer had been damaged. You can see the wood frame where the metal (aluminum) has been peeled back. Any suggestions from those who have had to repair this type of damage? If it were fiberglass I could do it myself but the aluminum panels look like you have to replace entire sections and the leading edge. The Trash trucks owner is paying to fix this but I want to make sure it is done right.
- 06 Salem LE 28BHS (axles flipped), Boliy Pro3600ES Generator
Dodge Dakota 4.7l HO (260hp/310torq), 131 in wheel base
3.92 gears with towing pkg, Reese dual cam sway control
Tekonsha P3 break controller
- 36 ft Monterey cabin cruiser, Stainless blender
Two 4.7 GXi I/O (2 x 320hp = 640hp)
carl.net is offline   Reply With Quote
Old 09-22-2012, 09:46 PM   #2
Herk7769's Avatar
Man, I am really sorry to hear this. Remember the damage may NOT be limited to the impact area. The twisting of these light weight frames at impact can cause damage in places not so readily visible.
Once they are hit they are never right again. Many will develop delamination and water damage later that will be traced back to the original wreck.
My opinion (if it were my trailer) would be to get it repaired and trade it in on a new one.
HAM CALLSIGN - KC3FFW
Old 09-22-2012, 09:49 PM   #3
Sorry to hear about the reck, could you post some pic of the damage?
Old 09-22-2012, 10:20 PM   #4
carl.net
ThanX fro the commiseration. The biggest issue I had was that the onsite security did not call me to say there was an issue even though my trailer was sitting askew...
A pic of the damage.
Old 09-22-2012, 10:31 PM   #5
carl.net
I appreciate the advice. I have been provided two quotes so far and both were for $4,500 which is getting close to more than I paid for the trailer... I will probably see what kind of job the dealer does on the repair and then run some tests using a sprinkler and a moisture meeter (the kind they use to test boat hulls) to test for leaks, and a laser level on the outside to check if the unit is still true. If everything seems right and it still pulls straight then I will just use it till I run into issues and then buy another used one to play with. Grin.
Old 09-23-2012, 07:06 AM   #6
Herk7769's Avatar
The issue I am talking about has to do with the fasteners that hold the skin on. Once they get loosened, they will continue to pull free. There is a tremendous amount of suction on the walls and roof of the camper when you are at highway speeds. It is worse when you leave the vents open when driving (if you have covers or forget one).
Your first indication that you had hidden damage might just be the skin pealing back on the far opposite wall; while insulation and household goods stream down the highway like it did to my friends old camper (who was hit lightly in a similar manner).
I will try to see if he still has the photos, but I recall he used a screw gun to reattach the wall in order to get it home.
Old 09-23-2012, 07:29 AM   #7
That looks like a pretty basic repair, even though they will have to replace most of the tin on that wall. It looks like the front wasn't damaged at all?
The tin-and-wood campers are easy to work on, and I see no reason why you shouldn't keep your camper after the repair.
bakken is offline   Reply With Quote
Old 09-23-2012, 08:30 AM   #8
carl.net
Though obviously a serious issue your description had me thinking about the old cartoons featuring Goofy... Grin. He was always prone to loosing a few items.
Old 09-23-2012, 08:36 AM   #9
carl.net
I have no knowledge of camper siding repair but if things look good after and during the repair to the technician then I agree that holding on to the camper and just using it make sense.
The front has no damage. The trash truck looks to have caught the corner molding and ripped backwards.
Old 09-23-2012, 08:56 AM   #10
caper's Avatar
Hope you have the damaged area covered. You do not want water getting into the front of the TT. You will have more damage by water getting in then the small opening caused by the truck. This is a common repair and a good RV repair shop will make a repair that is as good or better then the original. Good luck with the repairs and enjoy your TT for many years to come. The up side is that the aluminum siding is easier to repair the the fiberglass TT.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
