Old 03-03-2012, 01:50 PM   #1
Turn signal stays on towing headlights on
Georgetown 300 when towing a car and head lights on RV the right turn signal comes on and stays on. With head lights off it works fine. There was no wiring touched on the RV when tow was set up. When no tow works fine with lights on.
jadebox is offline   Reply With Quote
Old 03-03-2012, 02:02 PM   #2
geo's Avatar
Might be bad bulb or corroded wire in toad.
geo is offline   Reply With Quote
Old 03-03-2012, 02:02 PM   #3
Dave_Monica's Avatar
I imagine that it's the same thing with the parking lights on. You're talking about the turn signal on the towed car, right?
Sounds like either the receptacle or plug connecting the towed car isn't wired correctly. Seems like the wire for the parking lights and right turn signal are switched.
Old 03-03-2012, 02:06 PM   #4
turn signal
Had it checked at the tow shop. We can use the parking lights with no problem. ARRRRRRRRRRR
Old 03-03-2012, 02:07 PM   #5
With head lights off all works great. Headlights on and no tow it works fine.
Old 03-03-2012, 04:25 PM   #6
sounds like the ground wire in the towed item is on the wrong pin. I had that happen in a borrowed trailer and everytime I put on the lights the trailer brakes would slam on. the only way to tell is activate all functions from the plug using test leads and a probe
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
headlights, toad, turn signal
