Forest River Forums
Sunline User Photos
Old 08-30-2010, 09:12 PM   #21
well hell iggy, you're only a hop, skip, and a jump away.
kappel15 is offline   Reply With Quote
Old 08-30-2010, 09:45 PM   #22
If all else fails, break out the owners manual! I think I have found my problem. My TV does not have a audio out using the RCA cables. It has to be an optical cable which the ZX700 does not support. I believe that may be your problem too kappel15. I always use my dish while camping anyways so I can get that audio thru the overhead so I am not going to worry about it too much. If I decide to use the over the air antenna I will just have to settle for the audio coming from the TV.
phoneman06 is offline   Reply With Quote
Old 08-30-2010, 09:50 PM   #23
well, i'm not out yet. even forest river said it was suppose to go thru the ceiling speakers. and it they are wrong, there should be a way to connect the tv to the panel below the tv and get the speakers to work. and just so i can tell forest river, what page did you find that info on? thanks. kap
Old 08-30-2010, 09:59 PM   #24
Koodog's Avatar
On my unit you also need to make sure the audio input cable is plugged into the audio output on the TV. I just had this issue as I removed my TV from the wall during travel and hooked it up wrong. Had no sound thru the Concertone, but did have it thru the TV, until I plugged cable into the audio out. I had it in the video in on the TV.
Walt-N-Terry Sanford
03 Dodge Ram 2500 Diesel
08 Rockwood 8317
Koodog is offline   Reply With Quote
Old 08-30-2010, 10:00 PM   #25
Don't remember the page, but it is the page with the back view showing the connections and there is also a page showing how to hook up an external amplifier and it only shows using the optical cable. What size is your TV? Mine is 26".
Old 08-30-2010, 10:07 PM   #26
Koodog,
What size is your TV? I am guessing that some TV's have the audio out while other do not. Only plug labeled audio out on mine is the optical one.
Old 08-30-2010, 10:07 PM   #27
5th wheeling since 1991
Iggy's Avatar
What kind of TV do you have kappel?
A Toshiba 32" flat screen or?
2011 Rockwood Sig. Ultra Lite 8285WS by Forest River
2011 - 9 Trips / 66 Days Camping / 7,080 Miles
2012 Planned so far 35 days / 4,000 miles
2011 F-250, 6.2L Gas
Old 08-30-2010, 10:11 PM   #28
i think the screenitself is 22 1/2. what are you refering to about 'optical cable? also in my manual, it talks about the panel below the tv, and having it set to mp3/tv, and having jacks plugged into the far right two holes.
Old 08-30-2010, 10:16 PM   #29
it is a toshiba flatscreen
Old 08-30-2010, 10:26 PM   #30
Here is a link to the spec sheet to my TV. The second page shows a picture of the back of the TV in which you can see there is no RCA audio output. They are all labeled in.
http://www.tacp.toshiba.com/tacpasse...C100U_spec.pdf
» Online Users: 542
116 members and 426 guests
09grizzly1, 10Isola, 2000XLifted, 2Bushes, Acableguy06, Adony, AvalancheR-pod, bfast54, Bob Norquay, booneandbuck, Borwick, bsmall, Camping Dad, caper, carbonman, cardimom, Cccross3, cebaker, cmleach, coverup, cowpaddy, dashonthedash, Dave_Monica, dc31bhss, dckoski, DF5.4, donh, donn, DougP47, Drmstx62, Earth Station, Ed D, EdJunior, Ex5ver, F and E Damp, Falcon35, flc, Forbes, GASPEDDLER, GD13, GeorgieGirl, HemiCab, herk7769, Hob, hoffkm, HondoPatrick, Itsthetwoofus, JAJ73, JFM-jr, JKGreene, jodyand, JoeR, JohnT, Kamper, karnsr, katsmeow62, Kbrazieltx, kz08h5, lavigne, Lawfive, lefaivre, Linnemj, longarrow, lowbubba, LunaTech, Malco, Mark1978, mgcmn, michel, mike7431, miked11272, mstell2, mtworks, Newellri, Oakman, Old Jeeper, overthehillbill, papap, phrogdriver93, Pitcrew18, polkatronron, puckdad, radurecka, Rambler, RANGERBOB, rbq, realebill, RoadDog66, robynest, rparker, rschoono289, SabreMarv, shooted, Slow_movin, smithmdsmith, Sooner Travelers, Steve7575, Swinks, TaterColo, Tbeasley77, tbritt, tcoop48, teamgl, tentcamper1, Terier, tking01_2000, tking1866, tomwhite, transamz9, trudy66, TTNewbees, van_fl, vcarbona, wildcat2k6, Wisconsin Camper, youroo
Most users ever online was 881, 06-22-2011 at 11:07 AM.
copyright 2006 - 2010
Close [X]
