08-31-2010, 08:48 AM
#41
Lou Amadio
Thanks John.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
08-31-2010, 12:46 PM
#42
It seems the experts are chiming in here so maybe someone has a solution to my problems which is along the same lines but a little different.
It`s actually 2 different issues:
1) I won`t post the entire history unless someone wants it but the short version is when I plug in the 32inch Toshiba`s audio out jacks into the Concertone`s in jacks I get a beating or thumping type of feedback through all the speakers in the coach. I was told by Forest River that some type of a Noise filter is supposed to ship with those Toshiba`s and because mine was an upgrade after the purchase that the filter has not been installed and they are sending me one. Anyone know anything about this...
2) This is the stumper: I have had video problems from day 1 (over a year), with my system, first on the smaller 26inch Olivia with a constant horizontal set of lines in the upper right corner. FR sent a replacement ZX700 which fixed nothing, they had me check cabling, input voltages, and all sorts of other stuff, then they figured it must have been the TV so they sent a 32 Toshiba which was great but led to the problem above and actually made the video issue worse - basically unwatchable. Now the issue is that the entire picture shifts up and to the right and then back to original position, about once a second. They shipped a 3rd ZX700 and nothing changed. I should mention that the video issue is only when watching a DVD from the Concertone. And I`m definitely not here to bash, in fact I love everything about my trailer except for this TV and Concertone compatibility problem but I`m determined to figure it out perhaps with the help of some of you guys. Any help here would be appreciated.
08-31-2010, 12:55 PM
#43
How can the ZX700 effect TV? It can't. Is is just a sound system.
I just think both TV were/are bad.
One way to check is just hook up the tv direct to the antenna with no external speakers just the ones on the TV. This step will 1st verify the TV is good.
2012 Georgetown XL 37' - Model 378TS Dinghy - 2012 Fiat Pop 2,323lbs
08-31-2010, 01:02 PM
#44
The ZX700 is a DVD player as well... I`ve hooked up the TV to antenna with just the TV speakers and no issue. I`ve also hooked a portable DVD up to the Toshiba and again no issue. As well, I installed my 32 inch Samsung and both issues disappear. This is why I`m suggesting a compatibility problem, but if no one else has had the issue, then something else must be going on here.
Thanks for such a quick response by the way..
Marv
08-31-2010, 02:07 PM
#45
Lou Amadio
Marv,
Check the menu setting for video. Mine came from the factory set for PAL not NTSC.
For USA and Canada it MUST be NTSC.
I had similar issues with vidoe and that fixed it.
Audio is a different problem, but I would also look at the audio menus for a solution.
08-31-2010, 03:57 PM
#46
5 and 6 you have highlighted are ground and hot
08-31-2010, 04:24 PM
#47
Marv
Marv,
I stand corrected that it is a DVD player for video out.
The original issue was strickly TV audio input not making it to the speakers.
08-31-2010, 07:12 PM
#48
Miy ZX700 does have a noise filter installed in the audio out line. Not sure if it does anything but it did ship with the unit. Not sure if you have had the ZX700 out of the wall yet, but that is where I found my filter.
08-31-2010, 10:05 PM
#49
Originally Posted by herk7769
Marv,
Thanks for the suggestion but it didn't help. The video setting was auto so I switched it to NTSC - same symptoms.....
Marv
08-31-2010, 10:10 PM
#50
Thanks for the info, I've indeed had my ZX700 out of the wall, twice actually as I'm on the 3rd one trying to fix this issue. There is no such filter on the audio out line.
Do you have the same combo of 32inch Toshiba and ZX700? If so how is the picture quality of DVD movies in general?
Thanks,
Marv
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 670 |
| 132 members and 538 guests |
| accumack, acowie, apollumi, Bearcat55, Big Dawg, Bigjimt, BigR, bikendan, BlakeB, BOBBY B, boubou, bouldercamper, Brian78, brookside, Buffalohunter, Busman1947, bwbarnes, bwhunter65, Cafjackracing, CampinQueen, caper, cardinal4fun, Cascade Bob, cbvp, cdbus, cgreen1509, cgsparks1, chof16, Cincy6, clcarter, Cowracer, cstover, dasimser, dec1952, dfrauhiger, djorgensen3, donn, dretired, drvr84, dunnnc, flc, fordmantpw, Gene Ross, gljurczyk, go6car, gregm59, gregory, Greywolfmn, gwayne, Happy Vibe, herk7769, holymoly, Hoo Dad, hotrodj125, House97, JAJ73, jamesroadking, jamwiest, Janet H, jar3316, JENSENRVDirect, JFM-jr, Jhawkfan44, Jiggy, JJones, jlpurdy, johnnypal, judy3972, kegoneill, kixonrt66, Labzy, lazyb1626, lbhird, ldmcmahan, LFugate, lindy, lowbubba, Mark S, mhartzel, mhbandy, miatared, milw156, mlhalter, MT28rk, mtnguy, mtofell, myredracer, nailit, NeilM108, outdoorsbound, papap, Phil57, pick, pixleys, prof_fate, punkaccountant, rbrandon, realebill, RGH, ronhanson, rwzahm, sabre5er, savdog, shane1234, sledhead77, Snowsail, Stank Bait, tallens, Tee, Terier, tmmar, tom.keith, Tom47, tracetrimble, travyp, Triguy, True Believer, T_LMurphy, ubercamper, vasnipe, Vasvega, vc17, viper48, vp22er, VTX Al, wagon52, Warrior, whj77372, windrider, wnytaxman, wood1chuck, wvnurse1 |
| Most users ever online was 996, Today at 11:04 AM. |
