Forest River Forums
Sunline User Photos
Old 08-29-2010, 09:17 AM   #1
Tv issues
We just purchased a new 2010 rockwood 8315. The tv plays fine thru the ceiling speakers with a dvd in, but not just the tv. In the laminated quick guide, it even says to put the stereo unit on functions, and go to AU2 for the tv to play thru speakers. i even called forest river, and they walked me thru the steps and it didn't work. They said it must be wired wrong. But on the other hand, my dealers service manager says they are full of it, and the tv shouldn't run thru the ceiling speakers. who is right? i am hoping it is forest river, as you can't hear the tv cranked up on high, when the ac is running. thanks for any input.
kappel15 is offline   Reply With Quote
Old 08-29-2010, 09:59 AM   #2
grhodes50's Avatar
I'm guessing you have a concertone. These units are notorious for malfunctions. The speakers should work with the TV. It could be wired wrong, if not call FR back and get them to okay a replacement through your dealer. This is the "fix" they have on these units. They will continue replacing them until your warranty runs out. Most people buy a different brand and replace them theirselves. You can search this forum for what kind they bought and "how to" instructions.
I have the same tt as you and I have had mine replaced twice. Once in Feb this year and it's being replaced again now.
Maybe someone who has done this will post on here and explain it all to you.
Good luck.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
Winter 2011/2012 - Hibernating
Old 08-29-2010, 10:08 AM   #3
NWJeeper's Avatar
Ours only works in surround sound if there is a DVD in the player as the player is the unit that ouputs the sound to the speakers. Unless there is a cable from the TV sound output back to the player input the TV won't play through the surround sound speakers. However ours is a stand alone player, not one of the built in systems that they seem to like to use in the trailers. The units they have used in the trailers (usually Concertone) have been notoriously crappy and not worth troubleshooting.
Ed & Wendy
www.nwjeepn.com
Old 08-29-2010, 01:02 PM   #4
The Venturer TV in my TT is now garbage. It has is losing pixels by the hundreds each time I go out to the site. I carry an LCD TV in my car heat/cold bouncing and moving it for three years and have others also being treated the same way by employees. Do not have a problem, but VENTURER LCD's are not worth the money I paid. Junk!!
macbwt is offline   Reply With Quote
Old 08-29-2010, 02:36 PM   #5
On our 2010 8315BSS, in order to feed the TV audio through the ceiling speakers we must switch the Concertone unit to the AV2 inputs -- not the "AU2" input. Also make sure that all the speakers that you are trying to listen to are actually turned "on". Hope this helps.
...Allan
VTX Al is offline   Reply With Quote
Old 08-29-2010, 02:46 PM   #6
5th wheeling since 1991
Iggy's Avatar
TV does run thru the speakers system and yes it must be on AU2. I had to take my the system out and change 2 wires because mine did the same thing. They just plugged the TV output into the speaker system wrong.
2011 Rockwood Sig. Ultra Lite 8285WS by Forest River
2011 - 9 Trips / 66 Days Camping / 7,080 Miles
2012 Planned so far 35 days / 4,000 miles
2011 F-250, 6.2L Gas
Old 08-29-2010, 02:54 PM   #7
I re-iterate, just for the sake of clarity - On our new 8315bss, the input selection on the stereo unit must be "AV2" and not "AU2", to feed the TV audio to the stereo input. This makes sense as the "V" seems to indicate audio from a video source. I believe that the "AU2" input would select the XM source as an input, however I cannot check that out as I don't have an XM radio subscription. It certainly won't hurt anything to select "AV2" and see what happens !!
...Allan
Old 08-29-2010, 03:21 PM   #8
X2
Everett & Joan after 57 years together.
2004 1/2 ton Chevy & 2011 Rockwood 1809S
Emptypockets is offline   Reply With Quote
Old 08-29-2010, 03:50 PM   #9
Iggy's Avatar
NO I stated correctly. On my quick sheet it states for TV Sound
1. Turn on TV
2. Set function to AU2 for TV sound
We are NOT talking about TV output cable which may be AV Out.
We are talking input name to the sound system.
Old 08-29-2010, 04:20 PM   #10
thanks for the info guys, and i am betting you are both right. depends on how yours was rigged up. my quick guide also states AU2. i tried both it and AV2, with forest river on the phone. when next the camper goes into dealers to finish punch list, i better hear the right answer from the service manager, or sh/t will hit the fan
the owners manual on this tv reads like instructions for the space shuttle. i just want to watch tv
» Online Users: 542
112 members and 430 guests
09grizzly1, 2000XLifted, 2Bushes, Acableguy06, Adony, AvalancheR-pod, Bentley, bfast54, Big Dawg, bikendan, Bob Norquay, booneandbuck, Borwick, caper, cardimom, cat1956, Cccross3, cebaker, cmleach, coverup, cowpaddy, Dave_Monica, dc31bhss, dckoski, DDC, DF5.4, doberman, donh, DougP47, Drmstx62, Earth Station, EdJunior, Ex5ver, flc, flyrotor, Forbes, GASPEDDLER, GD13, HemiCab, herk7769, Hob, HondoPatrick, iluvlcy, JFM-jr, Jimmygee, JKGreene, jodyand, JoeR, JohnT, Kamper, katsmeow62, ken0042, kz08h5, lavigne, Lawfive, lefaivre, longarrow, lowbubba, LunaTech, Malco, Mark1978, mgcmn, michel, Michigan-traveler, mike7431, miked11272, mindenglock, mstell2, mtworks, Newellri, Oakman, onetonford, overthehillbill, padave65, papap, phrogdriver93, Pinesman, Pitcrew18, polkatronron, Rambler, RANGERBOB, rbq, realebill, rparker, rracer5, SabreMarv, sfrye5853, shooted, Slow_movin, smithmdsmith, Steve7575, Swinks, Tbeasley77, tbritt, tcoop48, teamgl, tentcamper1, Terier, thom01, tking01_2000, tking1866, tomwhite, transamz9, TTNewbees, van_fl, vcarbona, w021095, walterw11, wildcat2k6, Wildwood Danny, wingriders, Wisconsin Camper
Most users ever online was 881, 06-22-2011 at 11:07 AM.
copyright 2006 - 2010
Close [X]
