Old 12-25-2015, 06:36 PM   #11
I was able to get to reach the booster and splitter and remove them from the wall. All connections seemed tight
lennyluce is offline   Reply With Quote
Old 12-25-2015, 07:09 PM   #12
Left Coast
With TV on, see if by wiggl'n coax(s), anything changes....But, I'm still leaning toward receptical problem.....If you have a long enough extension cord, substitute power to tv to pedistal
Old 12-25-2015, 07:20 PM   #13
VinceU's Avatar
Is the light an LED fixture? If f so the problem may be RF interference which is entering the antennae amp, the splitter or the TV itself any of which are not grounded properly. My next call would be to a television repair shop for some free advice.
Old 12-25-2015, 09:07 PM   #14
I will try your suggestions. The lights are all LED in trailer.
Old 12-25-2015, 09:16 PM   #15
On our Windjammer the bedroom TV will go blank if the overhead light nearest the TV is on. I have read that it is the cheap LED light fixtures interfering with the TV signal.
Windjammin is offline   Reply With Quote
Old 12-25-2015, 09:29 PM   #16
wmtire's Avatar
Yes as Vince and Windjammin have pointed out, it is a known issue that some LED bulbs can cause interference with radio and television signals. But microwave and bathroom fan aren't usually a culprit unless something else may be wrong (or you have the led lights on at the same time). We have many documented cases and threads here with such on the bulbs. I'll edit this post with some after a search.
TV/ light outage?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-31-2016, 07:54 PM   #17
HW296's Avatar
FYI, most people are not aware that digital tv signals are broadcast at a much lower power than the old analog signals. They are affected more by wind and the distance you are from the actual broadcast towers.
I use an antenna from Spectrum Antenna, they can be found online and they have a large selection of antennas. the one I use when camping is a directional antenna and can pick up stations as far away as 150 miles.
Go to antennaweb.org and follow the directions. You need to know the zip code of where you will be and it will tell you the stations, compass heading and miles from the broadcast antenna. I would advise to print out all the documentation for each location that you intend to camp at. We camp at 20 of our favorite places and I have all of them in plastic sheet protectors in the trailer. Makes my viewing more enjoyable.
Chuck Kennedy
TV = 2003 1500HD 4x4 Chevy
Silverado Crew Cab 6.0L V8 W/3:73
2011 Rockwood HW296 16" Box
Tent Camper
HW296 is offline   Reply With Quote
Old 01-31-2016, 09:17 PM   #18
With the digital tv antenna you have to be right on, if your antenna is a little off you get nothing. I think there should be a special place in hell for that someone that thought this all up. All it was to sell more signals for cell phones
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-01-2016, 08:06 AM   #19
Every camper I have owned had issues with loose cable connection.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
