Old 09-27-2014, 05:25 PM   #1
Juju's Avatar
Question TV surround sound
Is anyone else having trouble with the surround sound in their RV? Also, good picture on LR TV, but snowy on BR TV, with satellite. We watched it at the rally in August without any problem, but now we have this problem.
Juju is offline   Reply With Quote
Old 09-29-2014, 09:26 PM   #2
Jimmerinwi's Avatar
For the snowy picture I would check the connections at all locations. Chances are something came loose during travel.
Somedays I wake up Grumpy, somedays I just let her sleep......(Ray Scott)
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 09-29-2014, 09:45 PM   #3
VinceU's Avatar
Also check the "splitters that cojoin the cables from the LR to the bedroom. Often they are not rated for Sat wiring and block or degrade the signal.
Old 09-29-2014, 09:45 PM   #4
Old car's Avatar
We have a brand new Sabre and I cannot get the television to play through the surround sound system. Everything else works fine--radio, cd, dvd, but not the television. I was going to ask folks about it at the Amana Rally and see if I can figure it out.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 09-29-2014, 09:48 PM   #5
Kaadk's Avatar
A lot of times they're only wired for video from surround sound to TV. Not wired for TV back to surround sound. You'll have to check to see if there's anything plugged into the 'Audio Out' on your TV and then make sure that connects to an input on the surround sound.
If that's ok. Next check the settings in the TV. Differs from manufacturer to manufacturer but in general there should be some kind of setting to enable the audio out. For some, you need to disable the TV's speakers to enable the audio out.
Old 09-30-2014, 06:15 AM   #6
Juju's Avatar
Thanks to all for your replies and suggestions. Will check the things mentioned later. Too foggy in Pa. now.
Old 09-30-2014, 04:42 PM   #7
Juju's Avatar
surround sound
The thing is...........the wiring is in the walls. No way we can get to it.
Old 09-30-2014, 09:49 PM   #8
Jimmerinwi's Avatar
Check the connections where the wall plates are. If there are splitters they'll be right there. Check the stingers(center conductors) and make sure there's no braiding touching the stinger.
Old 09-30-2014, 10:06 PM   #9
deartruc's Avatar
As far as connections to the radio go..as kaadk sais they only run one set of rca cables (red and white jacks) from the radio to the tv..you may want to run a second set for audio from the tv to the stereo.
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 10-01-2014, 06:15 AM   #10
Juju's Avatar
Red face splitters
Ok, guys, thanks. We will check. Foggy again this morning in PA.
