Old 03-08-2016, 09:45 AM   #11
Yes, I think your tires are fine for your trailer. I think you answered your own question anyways in 10K miles of travels.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-08-2016, 09:48 AM   #12
Flybob's Avatar
There are lots of reprogramming tools on the market that should work and cost less than $100. Here is one
Kent-Moore EL-50448 TPMS Tire Pressure Monitor Sensor Activation Tool
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-08-2016, 11:50 AM   #13
Don't quite understand the problem. We use a 2010 Tundra and I went from P tires to LT and the manual clearly shows how to reset it yourself from the cab. When we aren't towing I use a lower pressure and can reset easily. I would certainly think that on a GMC you could do the same. Good luck.
VMI'62
Edmund is offline   Reply With Quote
Old 03-08-2016, 12:11 PM   #14
Reprogramming your TPMS to a different pressure threshold, requires a GM Tech II tool. This job cannot be accomplished with any inexpensive aftermarket device.
I have a GMC Sierra 2500 and recently had mine reprogrammed by my local GMC dealer. The cost was $59. I'd check with another dealer. Any GMC/ Chevy dealer can do the job.
Some independent shops can also do it. In my case, the dealer was about the same cost as the independent that I contacted so I went with the dealer.
Since Ford/Firestone eplodergate, the car companies have all started requiring higher pressures to reduce their liability. My truck, with load range E LT tires specifies 65 PSI front and 80 PSI rear. These are crazy pressures that are required for maximum load, but result in uneven tire wear and a flinty ride. A quick consultation of the appropriate load/ pressure chart shows that 45 PSI all around is more than adequate for the loads that I typically carry (scale verified), even towing.
In my case, the TPMS would start complaining if the front pressures dropped below 60, and the rears below 65. The TPMS allows 20% variation above and below the setpoint, so I had my dealer set it to 50 PSI. This allows me to run a wide variety of pressures without the TPMS complaining, but will still warn me if my pressures drop to the minimum safe pressure. I'd recommend that you weigh your truck loaded as you will typically use it, then consult the appropriate load chart to see what pressures are required and have your TPMS accordingly.
hunterrick is offline   Reply With Quote
Old 03-08-2016, 12:37 PM   #15
Kenny kustom's Avatar
We're not talking about sensor activation.
We're talking about raising the pressure threshold.
Say you run 80psi and want the tpms to alert at around 60. Instead of the factory set 32psi.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-08-2016, 02:15 PM   #16
Tire cangeups
I will relay what my tire man told me yesterday during a long and fruitful conversation about truck, trailer and passenger tires. "What comes off goes on. What makes anyone think they know more about tires than the vehicle manufacturer. " and frankly I agree with him.
Strigflag is offline   Reply With Quote
Old 03-08-2016, 02:37 PM   #17
beagle22b07's Avatar
TPMS Limit Settings
Hunterrick. You said what I've been reading about in the Chevy/GMC truck forum. I did learn there is not an upper limit setting, only a lower one that sets off the alert. There appears to be a lot of 2500 owners that would like to run lower tire pressures, but hate seeing a warning light on their $50K+ trucks. I also think that after the lawsuits from exploding under inflated tires, the auto manufacturers are just protecting themselves. I'm sure your onboard computer keeps track of things like that. So maybe I can just run the LT tires because the higher pressure doesn't trip the sensors.
Larry & Chris (Abbey & Brody camping cats)
2016 Ford F-150 XLT Sport, Super Cab, 3.5 EcoBoost, 3.55, 4x4, MaxTow w/36 gal fuel tank
2015 Rockwood MiniLite 2104S, EMS-30HW, Carchet TPMS
Days Camped: 2015 = 51; 2016 = 59; 2017 = 20
If you're lucky enough to be camping......You're lucky enough.
beagle22b07 is offline   Reply With Quote
Old 03-08-2016, 02:45 PM   #18
Strigflag - I agree if your using the vehicle for what it was primarily designed for, but in the case of a tow vehicle, I think you should have the option to upgrade one step. On my old 2006 Chevy 1500, LT tires were listed on the door jambs where this 1500 GMC lists only the P metric size which I believe is a load range C. P metric is a nice ride for sure, but are they adequate for 10,000+ miles of towing.
Old 03-08-2016, 03:10 PM   #19
ccsvolsfan's Avatar
I bought LT tires when I had F150 and TireDiscorenter reset for higher pressure at no charge. also look at youtube videos.
ccsvolsfan is offline   Reply With Quote
Old 03-11-2016, 10:04 AM   #20
Too Tall's Avatar
I agree for some things, but OEM have to deal with cost constraints, competition and sometimes quality gets compromised. An RV is a perfect example.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
pressure, tire
