Old 01-22-2011, 12:13 PM   #1
TV to PC cont.
Thanks Lou you gave me a lot of good advice but before I do all this there is just one more question you might be able to answer me . When I follow thru with the next few steps that's when everything goes wacko.
I enclosed some photos of how far I was willing to without messing up my netbook, cause as soon as I hit the run or save botton next that's when I can get the images on the tv, but all streched out on the tv and my computer. In fact my computer is a real mess and the only way I found to get it back to normal is to download a new driver. So I guess the question here is how to I proceed without screwing everything up and get it on the the tv, with or without being on my computer.
I know I'm starting to be a pain in the a** or have been for awhile, but I do appreciate all your help.
Thanks.....Joe
[ATTACH][ATTACH]Click image for larger version
ID:	4277   Click image for larger version
JDickson is offline   Reply With Quote
Old 01-22-2011, 12:25 PM   #2
i don't know how to make a new thread, can u help me
boyle534 is offline   Reply With Quote
Old 01-22-2011, 12:34 PM   #3
Send a message via Skype™ to scubieman
This is called a thread. Go to forum select topic and before you select a thread. Itsays new topic at top.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 01-22-2011, 12:36 PM   #4
Thanks.....Joe
<img src="http://www.forestriverforums.com/forums/attachment.php?attachmentid=4276"/>
Your Computer and tv use different resolution therefore both Will not look pretty at same time.
Old 01-22-2011, 02:03 PM   #5
sherdep's Avatar
it either has to do with the resolution or screen size you pick for it to work right
why do you have to keep downloading a new driver - sounds to me like you may have a hardware issue or it doesnt switch back and forth correctly for the monitor output and back to the normal one
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 01-22-2011, 02:23 PM   #6
That's what I'm asking how to do it correctly so I don't have to download anything.
It must be clear I'm doing something wrong, but what? That why I posted the pictures to show how far I can go without screwing anything up. If you or anyone knows what I should do please let me know....
Thanks ....Joe
Old 01-22-2011, 02:30 PM   #7
sherdep's Avatar
usually it is just a function key and another key together that switches from the internal monitor to the output monitor
Maybe I am missing something here - thought I was trying to help.
I looked at the pictures but just looks like you are installing igfxconfig - maybe it is the wrong driver - check to see if there is an updated driver - alot of times there are fixes in the diffrent driver files
Old 01-22-2011, 03:50 PM   #8
Yes I read something about F-3 or F-6 to switch back and forth, but I have to get to that point. I know if either you or Lou were able to be here it would take only a few minutes to do this and then you would look at me as if to say what was so hard about that. But when you don't know, it's trying to say the least.
Believe me there is a lot I can do and compared to some folks I know I'm tech wizard lol.
Old 01-22-2011, 04:02 PM   #9
sherdep's Avatar
you tube has alot of videos related to: How to connect pc to TV
what model laptop you have?
What way are you connecting the pc to the tv - vga cable or HDMI or ?
What software are you using - I saw pc to tv on the bottom left but never seen that software before?
What device is the tv hooking up to - the TV or a direct tv box or?
Just trying to get detailed info to look up the manuals and see if I can give you some helpful advice
Old 01-22-2011, 04:19 PM   #10
Ok here goes. I have a Gateway Netbook LT20 (Not A Notebook) it has windows XP os
I'm using a 15 pin vga plug from computer to tv. The tv is an Olevia 32"
I have had a lot of people ask me this that and the other about what's on this computer to connect to the tv, but to tell the truth I don't know, I was hoping the pictures would help with that. There is no Direct TV box or anything like that, it's computer to tv only. No DVD player either.
Thanks.....Joe
