Old 02-19-2017, 04:50 PM   #21
Location: North of I-10 & South of I-94, but East of I-5 & West of I-95
yep...probably the easiest, I'll probably still try the BigAss Vise Grips first. Maybe I can grab on to the edge and twist it off.
2nd House is offline   Reply With Quote
Old 02-19-2017, 04:58 PM   #22
Iwannacamp's Avatar
My '17 trailer has strange looking heads also. Like an 8 point star...I was told they are shot in with a Ramset type tool. Vice grip them out and replace with sheet metal screws and flat/fender washers. I have to remove some of mine eventually to mount stuff.
2017 Puma 297RLSS
Old 02-19-2017, 05:48 PM   #23
wmtire's Avatar
Is it like in post #20
2011 Flagstaff 831 RLBSS
Old 02-19-2017, 06:53 PM   #24
Iwannacamp's Avatar
Ok. I quit guessing and took a couple pics..
Then I cut the plastic star off
Then I got a 1/4" nut driver... then helped get it out by prying and turning.
Then hammered it back in temporarily.
2017 Puma 297RLSS
Old 02-19-2017, 07:39 PM   #25
Picture #24 is them!!
So, they are not screws after all.
Very Good
Thanks for the help
Old 02-20-2017, 10:09 AM   #26
Chief
Must have changed recently. My 2015 has self tapping hex head screws. Glad you found out what they were
Razorbackfan is offline   Reply With Quote
Old 02-20-2017, 10:17 AM   #27
Very Good
Thanks for the help
Correct, not screws at all.
Hammershot, Ramset or drive pin fasteners driven in by a 22 caliber charge.
Not meant to be removed.
How stupid is that?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 02-20-2017, 10:20 AM   #28
Left Coast
Be sure to ask your dealer for the special tool to access underbelly.....A box knife!....
Old 02-20-2017, 08:52 PM   #29
I wanna camp...
How much prying did you have to do before they decided to come out, and what did you use to take the plastic star off?
Old 02-20-2017, 11:40 PM   #30
Iwannacamp's Avatar
I used my trusty pocket knife...plastic came right off. Needle nose pliers would prolly pull it off. I thought it was a screw so I righty tighty lefty loosey and it came out bout half way and stopped. I took said knife and pried under head while turning and it came out. I think loosen and use vice grips to pull out.
2017 Puma 297RLSS
Old 02-21-2017, 12:51 PM   #31
They use the powder actuated pins because they're fast and cheap compared to installing screws.
The easiest way to remove them is with a pneumatic chisel. Just pop the heads off them.
Gotta go campin!
