Old 09-09-2014, 05:03 AM   #1
arpipeliner's Avatar
Upgrade on black tank flush
Name:	ImageUploadedByForest River Forums1410256817.681796.jpg
Replaced plastic after the weight of hose and back flow had cracked it. A couple months the other plastic did the same.
Used a standard water connector. Hope this will end that issue.
arpipeliner is offline   Reply With Quote
Old 09-09-2014, 06:58 AM   #2
Infractee
Nice part! Where did you get? Pretty much a straight swap?
RhoZeta is offline   Reply With Quote
Old 09-09-2014, 07:34 PM   #3
At a small mom and pop RV store in moundsville, WV. It's just the standard water hookup thru the wall. Less than $20 and 15 minutes.
Old 09-09-2014, 07:36 PM   #4
Yes the washer on the plastic line slides down as u tighten the nut. Worked great this night with no leaking.
Old 09-10-2014, 10:22 AM   #5
Infractee
Thanks! I will have to look for some as well, I can tell the standard cheap one is not going to last long.
black, black tank, black tank flush, tank, upgrade
