Originally Posted by rp53
sorry it is in my sig. it is a 2014 chevy 4 door Silverado Z71
Your sig. says it's a 2015 and that might make a difference.
My 2014 GMC Sierra has an always-on/hot charging circuit regardless of key switch. I metered it once switch off, switch on/not running, switch on/running BUTTTTTTTTTTTTttttttt I can't find my post.
EDIT: OK, I found my post.
REVERSAL / RETRACTION!!
One of the worst problems on public forums is the definitive statement of
opinions as if they were
facts. Secondly, we are often merely
wrong when we post things as facts. I do that myself although I'd rather think I didn't. I did that very thing on this thread.
My son is certified as a World Class GM Master Technician. When I told him my opinion on this subject (meaning that the truck's charging circuit is dead when the key is OFF), he said, "I think that's wrong." He went home and researched the topic from a GM perspective - meaning he couldn't speak for the other two of the Big Three or the other entries in the RV towing business. Here's what he wrote me.
Positive cable off battery powers the HOT AT ALL TIMES input to the under-hood fuse block. The input to the 30A fuse is tied to this buss bar inside the UBEC. The output from the fuse goes straight to the 7-wire plug at the bumper with no relays, modules, switches or any other means for it to be remotely or automatically disconnected from the battery."
When members ask questions on this forum regarding a TV's (in)ability to tow a particular trailer, someone or more people will recommend that the OP weigh his particular rig to get real measurements/real numbers. I decided that might work for my 2014 GMC (please note I am not projecting this information on another manufacturer's units nor on older or differently configured GM units). I have a gas engine and a single battery on the truck.
Here are the voltage readings I found this morning from my 7-wire electrical socket measuring from tab marked
- to tab marked
12.46 – key off,
12.19 – key set to ACC mode,
12.14 – key on; NOT running,
14.81 – key on and running; T/H OFF.
With my key OFF, I have 12.46 volts ON at the trailer plug/socket.
Even after all this, my operating procedure will not change since I always have the trailer plugged into 110v AC when it's parked up by the garage before a trip. Therefore, I don't worry that the trailer cord is plugged into the truck because I ASSume the 110v - converter link will keep my trailer battery up so my truck battery couldn't be "drawn down" anyway. I doubt if I'll have any problems leaving the trailer connected to the truck for 90 minutes while I eat a steak while I'm out on the road.
Thanks to my son, I'm now more educated about how my own truck works. Your mileage may vary. The assumptions I gleaned from poorly conducted experiments and experiences were WRONG. I'm sorry. Consider metering your own voltage!"
