Old 07-20-2009, 05:14 PM   #1
acadianbob's Avatar
Voltminder is Useful Addition
We have the typical monitor in our TT that shows Full, 2/3, 1/3 state of charge for the battery. I never felt that I really knew what was going on with the battery as the monitor seemed to stay at full for a long time. Then, by the time it read 2/3, the battery was in a major world of hurt and had very little useful life left in it. So I bought a Voltminder and installed it in the BUSS right next to the converter. The Voltminder is simple; just a constant display of the battery voltage to the hundreth of a volt. I'm sure there are other products that do the same thing. What I discovered is that the standard trailer monitor read full all the way below 12.0 volts. 12.06 volts is 50% discharge! Needless to say, the standard monitor is WAY off. Full is about 12.6 volts; 2/3 is about 12.26 volts; 1/3 is about 11.8 volts and you should never go below that point. If fact, you should probably not go below 12.0 to 12.1. In any event, if you have had a similar experience with the standard TT monitor, I would highly recommend a simple, cheap device to REALLY monitor your battery condition. Now I know that I need to start the Honda genny once I hit about 12.1.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 07-20-2009, 09:46 PM   #2
Cyber Phrenologist
Radio's Avatar
And one of those AC voltmeters that plugs into the wall outlet, at about $15, is another really good investment. Air Conditioners are a terrible thing to waste
Along with other voltage sensitive things...
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
