Old 05-29-2011, 11:23 AM   #1
pattersonb's Avatar
Wall Mountings
Any experience out there at how to mount light objects (small mirror) to the interior wall of my Cardinal 30RKLE so that the mirror won't vibrate loose during travel. I've got multiple types of wood screws and anchors at home, but am unsure if they will work on the thin walls of the 5th wheel. Thanks!
pattersonb is offline   Reply With Quote
Old 05-29-2011, 12:48 PM   #2
Gadget63's Avatar
Send a message via AIM to Gadget63 Send a message via Yahoo to Gadget63
My initial thought would be to use velcro or liquid nails and forget about making holes.
Richie and Rose
2011 Ford Expedition Limited
2011 Flagstaff V-Lite 30WFKSS
nights camped in 2010 - 20
nights camped in 2011 - 28
Gadget63 is offline   Reply With Quote
Old 05-29-2011, 01:11 PM   #3
There is a special glue for mirrors. Liquid nails may eat the coating. I would look at using the 3m double sided foam tape made for mounting mirrors also. Apply it to the edges of the mirror, peel the cover off the other "sticky" side, and press on the wall, and you are done. Just make sure you get it straight and level. Also if you ever want it off, you can slide a piece of fishing line behind the mirror, and use it like a saw to cut through the foam and remove the mirror.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-29-2011, 01:22 PM   #4
I purchased my camper used and the lady had velcro up for her pictures. She said they held great and I was also able to remove them very easily when I purchased with out damaging the walls.
Brandy Hall
2010 Puma
30FQSS
1999 Ford Expedition
brandy2679 is offline   Reply With Quote
Old 05-29-2011, 05:21 PM   #5
wfmdfm's Avatar
3m
We have used the 3M removable tape for all of our pictures and they are still hanging. We picked them up at Lowes for 2.99 for 4.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
