Old 09-23-2010, 03:54 PM   #11
Villa Estate 392FLFB
The_Stuff's Avatar
Mine was not marked either. I am going to run my own lines for the water, the closet for them is just beside the water heater. and just past that is my breaker box. so i lucked out i guess.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-23-2010, 06:54 PM   #12
NWJeeper's Avatar
We ordred our rig set up for the W/D but never knew if we would do it or not. Luck just intervened and this landed in our laps and for free we couldn't pass it up.
The good thing is now the wife is going to have to figure out how to do without the 47 jackets she used to load up in that closet for a trip to Arizona! Go figure.
Ed & Wendy
www.nwjeepn.com
Old 09-23-2010, 08:49 PM   #13
kvtaylor's Avatar
Ed. You might want to wait installing the shelf above the washer. There is not much room. we put that rubber non slip on top of the washer and stored all of our laundry supplies (small bottles) in a plastic case. That way you can remove it and find what you want for washing. It also allows you to use a mirror to see if the connections are not leaking in the back of the washer. I check mine everyso often.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
