Old 09-04-2018, 01:25 AM   #41
Swampy's Avatar
Originally Posted by GAGator View Post
Ok, here is an update on my wasp hunt/kill adventure. I finally had to get a fogger to chase them out and another 20-30 came out in a hurry. I just held it up to the vents and fogged inside. So... the wasps are gone, two HUGE nests have been destroyed, and the vent cover is now in my workshop where I am going to screen it. Thanks for all the excellent suggestions. Since I have plenty of scrap screen left over from re-screening the back porch, I'm going to screen everything with a hole.
Don't use the fiberglass screen material on the water heater and furnace vents, else you may have ignition! Any wire type screen will work just fine. I used aluminum screen wire and hot glue on the refrigerator and just the screen wire on all the other vents.
Be careful with the wasp spray around any open flames .... you don't need a flame thrower! When you are done, you should blow out all those passages with compressed air before reassembly. No point in saving the wasp corpses and associated debris.
Good Camping Swampy
Jim (Swampy), Susie, Jimmy & The Chihuahua Crew
2008 Chevy Silverado LS, 4.3L, V6, 2WD, 3.23:1
2014 287 BHBE; 1981 JayRaven: Predator 3500i - Call Home Pearl River, Louisiana. on The Honey Island Swamp
https://www.forestriverforums.com/at...pic81807_1.gif
Swampy is offline   Reply With Quote
Old 09-04-2018, 03:56 AM   #42
GimpyD's Avatar
Wasp spray
It was mentioned that wasp spray could damage plastic parts. Try carb spray. It evaporates instantly, and kills wasps just as fast. Hint from an engineer friend...
GimpyD is offline   Reply With Quote
Old 09-04-2018, 04:04 AM   #43
GimpyD's Avatar
Wasps in vent
Try carb spray instead of wasp spray. Wasp spray is sticky, carb spray isn’t. It evaporates instantly, and kills wasps just as fast. That may keep from damaging plastic parts...I still can’t figure out why wasps and chiggers were created in the first place. Love honeybees, don’t even mind dirt dobbers, but those red wasps are just plain mean. Chiggers are useless except for making people miserable! WHY?!?! 🙄
Old 09-04-2018, 05:48 AM   #44
jd50i's Avatar
Carb spray has acetone and is just as damaging.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 09-04-2018, 09:32 AM   #45
Wolverine 1945's Avatar
I hear Carb Spray will damage Vinyl siding ???
Wolverine 1945 is offline   Reply With Quote
Old 09-04-2018, 11:17 AM   #46
I've always used a spray can of brake cleaner.
Iwritecode is offline   Reply With Quote
Old 09-04-2018, 11:49 AM   #47
Denver To Yuma In 90 Days
Last time I found a wasp nest in my furnace vent I fired up the furnace.
Took care of that nest in a flash!
JohnD10 is offline   Reply With Quote
Old 09-04-2018, 04:05 PM   #48
Wasp nest in heater vent
What we have been doing is putting a cat flea collars in the areas where mudwasps and other bugs might like nest. So far it's worked as I haven't seen any in there. Good luck
wnew813 is offline   Reply With Quote
Old 09-04-2018, 05:03 PM   #49
wasps, etc
Hi we put a dog flea collar in all the exterior vents, to discourage any critters that want to make those vents their home
barbie is offline   Reply With Quote
Old 09-05-2018, 07:47 AM   #50
Flea Collars,,, what a neat idea !!!
I would be very careful what I sprayed with Carb or Break cleaner !!!
heater, vent
