Old 08-21-2018, 11:19 AM   #1
GAGator's Avatar
Wasp nest in heater vent
I'm assuming it's the heater vent, but not positive. I have killed at least 100+ wasp with two cans of wasp spray and now I'm trying to get the cover off to go for the nest. Since it's just plastic, I don't want to break anything and I thought I'd check here and see if there is a recommended way to get the cover off. I have the two black plastic tabs lined up, but it's not moving. Pry it with a screwdriver?
The nest is behind the large cover under the word "Lite". Thanks.
Randy Lyons
Chickamauga, GA
2000 Forest River Wildwood Lite
2006 Ford F250 Lariat Diesel 4x4
GAGator is offline   Reply With Quote
Old 08-21-2018, 11:29 AM   #2
Flybob's Avatar
Think you are referring to the fridge vent as the heater vent looks like 3rd photo. Water heater looks like 1st photo. and fridge vent looks like 2ndphoto.
If you are talking about fridge vent, then line up the two small tabs on the bottom and wiggle them. There is a small rubber tab inside that will release from a rectangular hole. Once you release the bottom, there are two tabs on the top that will release bu pulling down. After you get rid of the bees, suggest you add screen to prevent them from returning.
Name:	water heater.jpg
ID:	183941   Click image for larger version
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-21-2018, 11:32 AM   #3
jd50i's Avatar
Without a picture not sure but it sounds like the refrigerator vent. If so, yes the plastic tabs turn 90 deg and you might need to gently pry with a screwdriver. I added stainless steel screen to mine to keep bugs out.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 08-21-2018, 11:40 AM   #4
GAGator's Avatar
Awesome! Thank you VERY much for educating me! I knew I could depend on you guys to help! I will definitely add screen before putting it back on. Thanks again!
Randy Lyons
Chickamauga, GA
Old 08-21-2018, 11:43 AM   #5
jd50i's Avatar
Don't forget about adding screen to;
water heater door
stove vent
A/C cover
furnace vent
and anything else the little buggers can get in to.
2014 Grey Wolf 21RR
Old 08-21-2018, 11:47 AM   #6
onetonford's Avatar
Be careful with the wasp spray it is petroleum based and it can damage plastic parts you have in that area.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-21-2018, 12:39 PM   #7
water heater door
stove vent
A/C cover
furnace vent
Like the bumper plugs. Click image for larger version
Name:	Exterior Mods 009.jpg
Old 08-21-2018, 12:54 PM   #8
Denver To Yuma In 90 Days
I've found that a quarter will fit those plastic tabs on the refer vents perfectly.
As for going after the nest...wait until after dark when they are all inside asleep!
They'll be too sleepy to chase you...plus you'll get them all at once!
Still...be prepared to run just in case...
"Just because someone has been "doing it for years with no problems" doesn't mean YOU should!"
2015 Heartland Prowler P292 5'ver
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is online now   Reply With Quote
Old 08-21-2018, 02:07 PM   #9
GAGator's Avatar
Ok, here is an update on my wasp hunt/kill adventure. I finally had to get a fogger to chase them out and another 20-30 came out in a hurry. I just held it up to the vents and fogged inside. So... the wasps are gone, two HUGE nests have been destroyed, and the vent cover is now in my workshop where I am going to screen it. Thanks for all the excellent suggestions. Since I have plenty of scrap screen left over from re-screening the back porch, I'm going to screen everything with a hole.
Randy Lyons
Chickamauga, GA
Old 08-21-2018, 03:26 PM   #10
Not sure if that screen would be safe for this kind of project...
Most especially the furnace and water heater vents.
heater, vent
