Old 03-14-2016, 11:43 AM   #1
dkrap's Avatar
Water heater
Neither AC or gas can make unit work
dkrap is offline   Reply With Quote
Old 03-14-2016, 11:45 AM   #2
wmtire's Avatar
Are you sure it has water in the tank itself (you may still have the bypass valves set for winter). Just turning on the hot water taps will not indicate this if you have the bypass valve incorrect still.
These two links may help:
Suburban's electric switch and much more
Hot water heater
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-14-2016, 11:53 AM   #3
Pickin' & Campin'
Can you give us more information?
Things like...
Tank type or tankless?
What have you tried to do to make it work?
Brand?
Did it ever work?
Batteries good and 12v supply OK?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-14-2016, 12:41 PM   #4
Head Rambler
Like said above, more info would be helpful.
Have you tried pressing the reset buttons?
Gotta go campin!
Old 03-14-2016, 12:54 PM   #5
I suspect the bypass valves are in winter mode
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 03-14-2016, 02:09 PM   #6
Water heater
Going to take guess and recommend you check small black switch in lower left corner make sure it is on.
Rich5117 is offline   Reply With Quote
Old 03-14-2016, 02:25 PM   #7
dkrap's Avatar
Thanks for info. Was asking for neighbor camper. He assured me there is water in the tank. He is frustrated with it and is not going to mess with it anymore. Thanks again.
heater, water, water heater
