09-06-2011, 10:24 PM
water Heater Deposits
Hello Everyone,
Today I drained my water heater and notice lots of white mineral deposits on the anode and the bottom of the water heater. Any suggestions on cleaning the tank. I read that you can use vinegar or CLR by filling the tank, leaving it for several hours and then flushing with plenty of water.
WestCoastRV'er
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
09-07-2011, 06:15 AM
The anode rod will have the white spots, its just doing its job. As for cleaning the tank, they make an attachment to the water hose that will fit in the tanks drain hole. This will add pressure and help remove the deposits.
Maybe vinegar if you want, that seems like alot of work to me. I would never put a cleaning agent ( CLR) in my fresh water, just never know what could happen.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
09-07-2011, 06:20 AM
X-2 on this. Youroo!!
09-07-2011, 07:33 AM
volunteer moderator
Deposits in the water heater are normal.
As mentioned I wouldn't put a cleaner in my hwh.
I have a piece of hose (a washing machine hose cut in half) that is about
3 feet long. I use it for filling my fresh water tank and in the fall when
I'm winterizing I can stick it in the drain hole and flush out the deposits.
Happy Camping!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
09-07-2011, 07:41 AM
Lou Amadio
Ditto on the NO CLR. As to acid (vinegar) in the water heater; your anode is giving up its life to protect your water heater's internals from acidic water that would eat your cast iron boiler and electric heating element. No need to help it die.
The bits in your heater are normal crud (bits of magnesium anode and calcium from hard water) Just flush it out good with a wand to prevent them from finding their way into your hot water faucets.
Amazon.com: RV Water Heater Tank Flushing Tool: Sports & Outdoors
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
09-07-2011, 03:09 PM
thanks everyone
I like the idea of not using any CLR or vinegar. Never thought of just flushing it out several times a year for prevention. Last winter I used rv antifreeze and don't plan on doing it again because it took quite a while to get the rid of the taste. Just drain, empty hw heater and blow lines with compressor.
WestCoastRV'er
3P ProPride Hitch
RV Mods
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 664 |
| 128 members and 536 guests |
| acowie, apollumi, Bearcat55, Big Dawg, Bigjimt, BigR, bikendan, BlakeB, boubou, Brian78, Buffalohunter, Busman1947, bwbarnes, bwhunter65, Cafjackracing, CampinQueen, caper, cardinal4fun, Cascade Bob, cbvp, cgreen1509, cgsparks1, chof16, Cincy6, clcarter, cory1, Cowracer, cstover, dasimser, dec1952, dfrauhiger, djorgensen3, donn, dotsonjc, dretired, drvr84, dunnnc, f1100turbo, flc, fordmantpw, Gene Ross, gljurczyk, go6car, gregm59, Greywolfmn, gwayne, Happy Vibe, herk7769, holymoly, Hoo Dad, hotrodj125, House97, JAJ73, jamesroadking, Janet H, jar3316, JENSENRVDirect, JFM-jr, Jhawkfan44, JJones, jlpurdy, johnnypal, judy3972, kegoneill, kixonrt66, KKapa, lazyb1626, lbhird, ldmcmahan, leadfoot, LFugate, lindy, lowbubba, Mark S, mhartzel, mhbandy, miatared, mike54, milw156, mlhalter, MT28rk, mtnguy, mtofell, myredracer, nailit, NeilM108, outdoorsbound, papap, Phil57, pick, pixleys, prof_fate, punkaccountant, realebill, RGH, ronhanson, rwzahm, sabre5er, savdog, shane1234, shrimper, sledhead77, Snowsail, Stank Bait, tallens, Tee, Terier, tmmar, tom.keith, Tom47, tracetrimble, travyp, Triguy, True Believer, T_LMurphy, ubercamper, Vasvega, vc17, viper48, vp22er, VTX Al, wagon52, Warrior, wfmdfm, whj77372, windrider, wnytaxman, wood1chuck |
| Most users ever online was 996, Today at 11:04 AM. |
