Originally Posted by Jayspoint
How do I know if I have a 110 water heater or strictly propane source water heater ?
Jayspoint, as others have pointed out, it's hard to give you accurate advice without knowing what RV you may have, or what water heater is installed.
Forest River uses Atwood and Suburban tank type water heaters, and various brands of tankless water heaters....... so it's not a one size fit all thing.
If you have a park model, it could even have a residential style water heater.
________________
If you ONLY have one switch inside your RV to the water heater, then that's going to be to the gas/propane side.
An Atwood tank type water heater would have a second switch right there, that controls the electric heating element...if equipped.
A Suburban tank type water heater "could" have a second inside switch to control the electric heating element if equipped (SWDEL model)...... or could ONLY have an electric heating element switch on the face of the water heater (SWDE model)
Both the SWDE and SWDEL models operations and switches are explained in detail at this link:
http://www.forestriverforums.com/for...ore-36197.html
If you have a tankless (on demand) water heater, then it's most likely going to be gas only.
