07-22-2016, 09:52 PM
Water heater switch
Hello
On my Heritage Glen fifth wheel i have a on/off switch at the water heater. I also have a water heater switch inside. When is the inside one used?
07-22-2016, 10:05 PM
Outside on all the time.
Inside to control it.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
07-22-2016, 10:16 PM
Inside is when you want to use gas, outside is for using electric.
If both are on you are using both electric and gas.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-22-2016, 10:17 PM
Unless you have both an electric and a gas switch inside... Along with an electric switch outside.
2016 Sabre 36QBOK
07-22-2016, 10:19 PM
x2!
But make sure that the WH is full of water before you turn the electric switch on.
Otherwise you will burn out the electric heating element.
Originally Posted by seicken
Hello
To properly answer this one would need to know "What MFG and Model# of the W/H" ! The Wrong "WAG" could cost a Member some $$! Youroo!!
07-23-2016, 05:45 PM
X2 to what Youroo said. In order to answer the question correctly we need to know the mfg. (and the model would be nice) of the water heater.
Gotta go campin!
07-23-2016, 09:25 PM
How do you use both gas and electric?
07-23-2016, 09:28 PM
What MFG and Model# is your Heater?? Youroo!!
07-23-2016, 09:38 PM
you can run both....those that do say it recovers faster.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
07-23-2016, 09:52 PM
On my rig You can run both if you are on shore power or have your generator running. You put the outside switch on the WH to on and also turn the inside switch to on for gas you now have propane heating and electric element heating.
Retired Navy
2016 Flagstaff 26 FKWS
07-23-2016, 10:11 PM
Hmmm have to check. We have Heritage Glenn. 246 rlbs
07-23-2016, 10:33 PM
Please provide the Manufacturer and model # of your water heater!!!!
2011 Traverse LT, 3.6L, FWD
