Old 06-23-2014, 08:27 AM   #11
THanks for the quick reply. Ok so no one took a shower and I did NOT do the black flush at this point. It was our very first camping trip The sink has been used and the shower is on the other side of bathroom ( see pic) It does look like the water is gathering around the base of that wall and leaking out to the right probably because we were on a bit of an incline. It did rain plenty the first night. So if it is a roof leak do I just fix the leak or do I have to do further tear up?? I have no idea. First camper . First trip. Thanks again.
tbeefitz is offline   Reply With Quote
Old 06-23-2014, 08:35 AM   #12
NELA
Weezer's Avatar
Herk, look where that window is located on the bunk wall.
And there's a skylight in the bathroom.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 06-23-2014, 08:41 AM   #13
There is also a cargo door thingy lol on bottom bunk wall.
Old 06-23-2014, 08:52 AM   #14
Plain Old Member
On the roof, is there by any chance a vent or two coming through the roof in the area of that wall? If so that may be a starting point to check the dicor sealant.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-23-2014, 09:08 AM   #15
Herk7769's Avatar
You are right. I see the shine from it on the floor.
My money is on a leak at the skylight.
Herk
HAM CALLSIGN - KC3FFW
Old 06-23-2014, 09:10 AM   #16
Herk7769's Avatar
Water will always find a path (sometimes even "up" due to wicking), but in this case it is most likely down from the roof; possibly from the skylight.
If it has not been leaking long, just repair the leak and the camper should dry out without too much damage. Wait; and wall delamination and permanent, EXPENSIVE damage will occur.
Old 06-23-2014, 09:24 AM   #17
Herk7769's Avatar
On second thought you could also be right. If there is water under the bottom bunk, I would buy this as the source as well.
Old 06-23-2014, 09:53 AM   #18
Ret E-9 Anchor-clanker
donanddona's Avatar
The next day after the rain did you find branches laying about the camp site? One might have hit the roof and bounced off the roof. Thus leaving a small tear. Standard roof repair in a caulking gun from H-Depot or Lowes can seal it. Seams like a waste of sealant but the cost (7.00) out weighs the cost of water damage. I good roof inspection is necessary after a storm. Lets just say been there done that.... :-)
donanddona is offline   Reply With Quote
Old 06-23-2014, 10:19 AM   #19
nuisance's Avatar
This last trip out with 2 granddaughters we had a leak from the slideout. Come to find out we where not as level as I thought we where. Re leveled and no more water.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 06-23-2014, 04:22 PM   #20
VinceU's Avatar
I think to check the plumbing supply to the toilet. Could be it's running down the hose! (Dripping)
door, leak, roo, water, water leak
