Old 06-22-2014, 02:18 PM   #1
Water leaking on floor by Bathroom door???
Hello,
I noticed that there is water leaking on the floor by the wall in the bathroom. Flushed the toilet a million times. lol, not that?? I have a Wildwood 26tbss. Any info would be greatly appreciated.
tbeefitz is offline   Reply With Quote
Old 06-22-2014, 02:27 PM   #2
pictures of problem
Old 06-23-2014, 07:12 AM   #3
Take The Road Less Travld
MuddauberE's Avatar
Originally Posted by tbeefitz View Post
Hello,
Has it rained in the last 24 hours or has anyone taken a shower? Did you wash the trailer or wash any dishes? I'm not sure if the sink is near the bathroom but we would need a little more information. Water leaks are no fun, I've had them several times. You just have to back up and think about what's happened recently regarding water.
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 06-23-2014, 07:15 AM   #4
rattleNsmoke's Avatar
Have you done a black water tank flush just prior to noticing that leak? If so, you might have an anti-siphon check valve leaking.
rattleNsmoke is offline   Reply With Quote
Old 06-23-2014, 07:52 AM   #5
I've had the same problem camping this weekend. I thought a water line was leaking but discovered that the shower drain leaks around the flange. It was sealed with plumber's putty which has cracked and separated. Also the fittings were vibrated loose.
Should there not be a rubber gasket or at least a flexible sealant there? What to use to fix it? And should the fitting threads have teflon tape or pipe dope on them?
On my camper (2013 surveyor sport 24) a small vent in the bottom of the shower stall is the access point.
The shower floor flexes when you step on it so that compounds the problem.
Most of the water leaked into the area between the floor "sandwich" and was dripping out the bottom of the camper.
frcamp is offline   Reply With Quote
Old 06-23-2014, 07:58 AM   #6
Plain Old Member
Curious on the black flush as well / anti siphon valve. Seems to be a hot topic over the last week. Not many install them in the walls, but there still are those few thoughtless engineers who think hey, let's just put it here. Never mind they're VERY prone to leaking or sticking open.
Got any way to access inside that wall? Not hard to add a nice looking access panel there if need be. We've added several to access plumbing and everything else.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-23-2014, 08:04 AM   #7
Herk7769's Avatar
That water looks like it is coming out of the wall.
I believe you have a roof leak.
This is an emergency.
Get on the roof and look for a dried/cracked Dicor seal that is allowing water to enter the camper. The water is traveling along the inner roof panel to a place where it can descend. It has found that in a screw penetration that secures the wall.
You are going to have major issues very soon if you don't find your leak.
HAM CALLSIGN - KC3FFW
Old 06-23-2014, 08:17 AM   #8
NELA
Weezer's Avatar
Same thought I had Herk; water down thru the wall
Looks like a brand new RV. I'd be draggin' that RV back to the dealer *this* morning.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 06-23-2014, 08:22 AM   #9
Herk7769's Avatar
Profile says a 2013 so it "may" still be under warranty.
Most likely it is in its second season.
To the OP.
Did you do your semi-annual required roof maintenance? (see manual)
They may not honor your warranty if you have never done the required maintenance.
Sort of like never changing the oil and trying to get engine work done under warranty.
Old 06-23-2014, 08:22 AM   #10
Plain Old Member
Kind of waiting on confirmation from the OP if it was even raining, was flushing tank, or who knows what. Might be a roof leak, or could be an anti-siphon.. I'd guess gray / black vents run up that wall maybe? Need a little more info I think before anybody can really narrow it down.
door, leak, roo, water, water leak
