Old 08-01-2016, 06:35 PM   #1
Water Leaking Under Rain Gutter
Hi all, complete noob here. Just bought our brand new 2504S trailer. Always been tent camping. Been out twice already and everything seems ok. My issue is water streaking down one side(so far) about 2 feet before it hits the rain gutter spout at the end of the trailer. It does this in three particular spots. So to investigate I went on the roof and watched the water condensation from A/C flow down roof and into gutter. Everything is fine. But once that water hits those three particular spots it comes out from under the gutter. The gutter spout at the end still works great. Any advice as to what is going on would be greatly appreciated. How are the gutters attached to side of trailer? I didn't see any holes at top of gutter where the water streaks were starting. Sorry this is long. Thanks in advance.
2007 Ford F-150 5.4L Max Tow Package Husky Centerline TS WDH/Sway Control Prodigy P3
2017 Rockwood Mini Lite 2504S
Ramshackle71 is offline   Reply With Quote
Old 08-01-2016, 09:32 PM   #2
Same issue, but only in one spot. Been wondering about a fix also, so subscribed!
Sent from my SM-T320 using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 08-06-2016, 06:38 PM   #3
BDavis's Avatar
Is it a seam in the "gutter"? Mine had seams that leaked. Little clear silicone caulk fix er right up.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 08-06-2016, 06:53 PM   #4
Out of Order
Same issue with our new Wildcat. Turns out a gutter joint wasn't siliconed at the factory. The gutters on our trailer are NOT single runs of plastic, but rather several pieces siliconed together for the run. A little dab of silicone fixed the issue immediately.
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
todtc318 is offline   Reply With Quote
Old 08-06-2016, 07:08 PM   #5
You have plastic gutters?????????????
Mr Havercamp is offline   Reply With Quote
Old 08-06-2016, 07:24 PM   #6
Out of Order
You're right...metal gutters, plastic downspouts. Same reply however....non-siliconed joint between runs.
Old 08-07-2016, 08:46 AM   #7
I was gonna say.........I thought maybe they found another way to squeeze a few more pennies out of material costs.
Old 08-15-2016, 10:50 AM   #8
i had metal gutters on my old trailer with same caulking on joint got old and leaked. I scrapper out the old stuff and sealed it with silicone. It'e been fin ever since.
2017 Cedar Creek Cottage 40CCK
Gibbsey is offline   Reply With Quote
leak, water, water leak
