06-11-2019, 10:10 AM
Water pump runs when not in use
We have a 2018 Coachmen Freelander 21RS MH. At times during the night the water pump goes on for a few seconds, and then stops. This happens when with water in the tank with the pump on; OR when hooked up to city water with pump off. Any reason(s) why this is happening? Thanks for all your responses.
06-11-2019, 10:13 AM
waybeck2018
Maybe a minor leak in the system somewhere? Just a guess but it could be that.
2012 F-250, 6.7 Super Duty Powerstroke; 2019 291 BR Primetime Tracer,
Days camped in 2018-61
Looking Forward to Completing This Map Soon !
06-11-2019, 10:15 AM
The pump will run if the pressure drops , either a slow leak or the check valve in the pump is allowing the water to back flow . However if you are on city water with the pump switch off and it comes on you have a different problem maybe switch is bad allowing the pump to receive voltage or ???
06-11-2019, 10:21 AM
Comming on when pump is ON.....Have a slow drip / leak somewhere releiving pressure.
With pump OFF and on city water.... makes no sense at all.
FYI... DO NOT SWITCH PUMP ON WHEN HOOKED UP TO CITY WATER> EVER.
X2
06-11-2019, 10:43 AM
Not at all uncommon. The valves in the pumps, from what I've seen are rubber flapper valves sealing against a flat plate. In theory, they should seat flat. Sometimes one or the other aren't totally flat or there may be a piece of grit or sediment from the tank preventing that, but the pump still does it's job. If you took the head off the pump, you might see it as described. As long as you're pumping and not filling the fresh water tank from the city fill, don't sweat it! Another good reason to filter all the water that goes through your RV even when filling the potable tank
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
06-11-2019, 12:28 PM
Do you have an ice maker? Pump will run when it cycles.
06-11-2019, 12:40 PM
Good morning, check for water under the kitchen/ bathroom sinks, outside shower and compartment in behind the tub/ shower. The culprit may be a faulty 10 cent washer where the faucett connects to the taps.
Cheers!
Phill
06-11-2019, 12:42 PM
Is it common for a water pump to run when it’s turned off? I don’t think I’ve come across that.
06-11-2019, 12:49 PM
Sorry, missed the cty connected pump off part. I'd suspect that claim. No way to power the pump if switch is off unless shorted switch or wiring fault. but, as you know not uncommon for pump to cycle with switch on at night
14K Equalizer
06-11-2019, 12:56 PM
Don’t discount the possibility of a small leak. It can be any where in any line or fitting or just a pump valve not seating properly. A minor leak ignored is a guaranteed major repair eventually. I had a pin hole develop in the water heater bypass valve that I didn’t catch until it began to drip under my trailer and now I have a soft spot in my floor to repair.
2018 Forest River Wildwood 5th Wheel
2011. RAM 2500 Diesel Standard Cab 2Wheel drive
US Army Retired
06-11-2019, 01:05 PM
I dont think so. Sure pump is OFF. Had outdoor shower slow drip as a culprit and also a slight drip from low point drain cap.... Bou not when pump switch was OFF.
06-11-2019, 01:25 PM
It won't hurt anything if pump is on with city water , just won't help any !
06-11-2019, 01:26 PM
Sounds like a defective switch or possibly miswired Switch is easy to replace. Most use push on connectors. Switch is readily available at RV repair center or even some Walmart stores. Take the existing switch with you to gat a match. There are many different switches.
US Army Retired
06-11-2019, 02:00 PM
Water Pump runs when not in use.
Could be air in the lines.
06-11-2019, 02:07 PM
Read on here several times that it will cause check valve to lock up between city and FW??
06-11-2019, 02:12 PM
isn't there normally a fuse in the pump power line near the pump? pull that fuse and check to see if voltage is present with the pump on/off switch in both the on and off positions. the pump should not turn on under any conditions with the pump switch in the off position. imagine what it could do to a battery while being stored if it just turned on regardless of the switch position.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
06-11-2019, 02:22 PM
Id like to know how this turns out.... Please report when resolved.
Q: If you unhook city water.... Have full fresh tank (or plenty), turn pump swittch OFF, ... Now open a faucet somewhere. What happens? Water Flow?
06-11-2019, 02:39 PM
I do not leave my freshwater pump on when I am not using.... water.
There are many possibilities of where your 'leak' is. Yes, you have a 'leak' that is bleeding off the water pressure. (and I never use the fresh water pump when I am hooked up to city water). After looking the suggestions over. What about a slow leak at your toilet? Water heater release valve?
I had a small leak for years to I could not find. The fresh water pump would come on for a short time every 5-10 minutes when the pump was on. Looks for years on why..... I parked our unit more or less 'level' all the time. the a rain storm was forecast and I 'tilted' the unit to the slide out side where rain would flow off. When we had the fresh water pump on for a while, a very small stream of water was coming from under the wall at the tub wall location. Turned out the connection was not screwed into the tub faucet tight enough and there was a small leak. Why did we not see this leak for years? under the tub is a cut out in the floor where the u-pipe from the tub stuck down. the water go into this cut out and leak into the under belly cover and was never noticed. Had to peel the wall back to tight the water connection......
Brother Les
06-11-2019, 02:40 PM
Never heard of or experienced such a thing . nor does it even sound reasonable. The check valve works when on city water to prevent filling the FW tank and when on pump to prevent back flow . having pump on when city water is on would make no difference to the check valve .
