Old 05-13-2013, 02:50 PM   #1
Tony S's Avatar
Water pump wont stop
The water pump will stop when taps are off, but every 10 seconds it starts up for a second then stops. Then again and so on. I checked all taps for air but still does it. Anyone have any idea??
Tony S is offline   Reply With Quote
Old 05-13-2013, 02:57 PM   #2
You've got a leak somewhere or a defect in the pump.
Old 05-13-2013, 03:01 PM   #3
TURBS's Avatar
Did you purge all the air from the water heater relief valve?
Old 05-13-2013, 03:01 PM   #4
Tony S's Avatar
Can't find any leaks, must be a bad pump.
Old 05-13-2013, 03:03 PM   #5
Tony S's Avatar
Yes, let air out of valve, opened all taps.
Old 05-13-2013, 03:04 PM   #6
TURBS's Avatar
The pressure switch may be faulty.
Old 05-13-2013, 03:06 PM   #7
Tony S's Avatar
Pressure switch inside the pump?
Old 05-13-2013, 03:07 PM   #8
TURBS's Avatar
Its actually bolted to not in.
Old 05-13-2013, 03:12 PM   #9
TURBS's Avatar
http://www.pumpvendor.com/Shurflo_Parts_List.html
Old 05-13-2013, 03:13 PM   #10
Tony S's Avatar
Oh okay. I will have to have it looked at.
Old 05-14-2013, 05:14 AM   #11
Tony S's Avatar
That's for all the help, turns out the low point drain did have a small drip under the trailer. I tightened it up and the problem stopped.
Old 05-14-2013, 06:05 AM   #12
TURBS's Avatar
Good deal !
