Old 05-10-2011, 09:07 PM   #1
Waterpump - 2007 Wildwood
I just bought a used trailer with no manual. Can anyone help me with some details of the waterpump. Does the waterpump automatically come on to prime the system when running on battery or do you have to manually turn it on? and how long do you turn it on for?
Also, dumb question, what in the white hole in the wall behind the entertainment unit? Something for satelitte perhaps? Thanks in advance.
Kabarf is offline   Reply With Quote
Old 05-10-2011, 10:23 PM   #2
bikendan's Avatar
i'm sure you have a Shur-flo water pump. find out the model and go to their website for a manual.
there should be a red switch next to the command center.
ours is next to the DSI switch, for the water heater. you turn it on and should hear it run and yes, you let it run until it stops. if it doesn't stop, you either have no water or you have a water leak.
FR doesn't have anything other than the Shur-flo paperwork, in the owner's manual.
with no pics or trailer model number, it's hard to answer the hole question.
