Old 04-01-2011, 02:55 PM   #1
Shasta1's Avatar
Watts or Amps?
If I'm computing my power requirements in order to properly size my solar system, should I do it in watts or amps?
Shasta1 is offline   Reply With Quote
Old 04-01-2011, 03:11 PM   #2
Watts, unless you have a gymnasium sized solar setup.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
Old 04-01-2011, 03:13 PM   #3
I'm not expert but they are a bit interchangeable, I was taught this formula...
Watts = AMPs x Volts
And of course using a little high school math you can rearrange this formula as necessary. For example: 24 Watts = 2 Amps x 12 Volts. So in short Watt is the power used (or provided) at the rated voltage. Watts are normally used in calculating solar power requirements.
brianb is offline   Reply With Quote
Old 04-01-2011, 03:27 PM   #4
prof_fate's Avatar
Think of it like a garden hose.
Amps is the size (diameter) of the hose
volts is the pressure
watts is the gallons that comes out.
more volts = more pressure. more amps needs a bigger hose (or wire).
with a bigger hose or more pressure you can (but don't have to) get more water (watts).
If you're filling a bucket and need 5 gallons of water with a firehose or a straw you still need 5 gallons, one just takes a lot longer.
So if you are trying to charge a battery you are filling it with watts (measured per hour, or watt-hour, or for a house killowatt hour ( thousand) kwh).
To run a 5 w bulb for an hour takes 5 watts. If you run it off a battery for 10 hours you used 50 watts of power, total. So to recharge the battery you need to put 5 watts back in.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
