Old 11-02-2014, 09:55 AM   #11
When I first saw the thread title I thought it said, "WD-40 Fact and Friction".
Ham_Bone is offline   Reply With Quote
Old 11-02-2014, 01:21 PM   #12
Infractee
Indeed, it is a horrible lubricant. In fact, if you spray it on something that is greased (like a bearing) it will dissolve the grease and the bearing will be ruined. I would not use on a painted surface either, the naptha eats clear coat, turns it cloudy looking. If you need a cleaner there are many cleaners that are far better, if you need a lube there are tons and tons of lube products far better. To me using WD-40 to fix a problem is akin to using duct tape to fix problems, short term fix at best.
The stuff is crap and it smells as such.
RhoZeta is offline   Reply With Quote
Old 11-02-2014, 04:17 PM   #13
MacDR's Avatar
I find it amazing that the lubricant recommended for my Superglide is WD40 or 3 in 1 oil to be used on the way tubes and plastic wear plate on each day of use.. I chose 3 in1 oil.
Columbus 340RK
43 days Camping 2014 'Winterized'
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "14"
You can find us: Egg Harbor Campground 7/9 - 7/11
MacDR is offline   Reply With Quote
Old 11-02-2014, 04:36 PM   #14
Dazed & Confused
M&K Hoffman's Avatar
Yep WD40 is a water displacement agent and it does some other things well. As for spray lubricate, IMHO yo can't beat Slip Plate.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 11-02-2014, 04:38 PM   #15
MacDR's Avatar
Thanks.. Will give it a try.
Columbus 340RK
2014 Columbus 340RK
Old 11-02-2014, 08:26 PM   #16
Canadiancrew's Avatar
I would agree. It's not a great lubricant. More of a solvent. I do use it as a penetrating oil but not for permanent lubricant. The solvent evaporates and what's left does not do much.
As for cleaning do you really want to put that much solvent into ypur environment.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 11-25-2014, 09:57 PM   #17
Fact: WD-40 used on machinist tools will lead to "black rust". I was taught this back in 1969 while taking machine shop course. The instructor used WD-40 on a piece of tool steel which had been heat treated and ground to a mirror finish. He used another product on a sister piece of this steel. Two days later the WD-40 coated piece started showing small black spots on it then five days later it looked as though it was infected with something. The other piece never showed a change. Just saying that WD-40 is not a good metal preservative.
Thurman is offline   Reply With Quote
