09-12-2017, 05:56 PM
WD Hitch Recommendations
Hello. Looking for recommendations for a weight distribution system. I have a 2018 Puma 32RKTS, hitch weight is 1,137, dry weight of trailer is 7,673. I use a 2014 F150 EcoBoost, 3.5l v6 with a towing package with max trailer tow of 9,200. I just got the Puma this past June. I previously (trying to sell now) had a Coachmen Catalina 26BH that weighed much less, so I have the Reese SC Weight Distribution Kit that I'm using right now, but it's not quite adequate enough, specifically the trunnion bars. Looking for options to get a system that can safely handle this heavier rig.
I looked at the Andersen MFG 3305, anyone using this system?
Thanks....
09-12-2017, 06:02 PM
Equalizer!
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
09-12-2017, 06:16 PM
Originally Posted by Handydc
Equalizer!
X2!
2015 RAM 3500 Cummins LB 4x4
2018 Rockwood Signature Ultra Lite 8328BS
what model?
09-12-2017, 06:26 PM
I have an Equal-i-zer 10K weight distribution hitch for my travel trailer -- to get the best size for your trailer, go to the Equalizerhitch.com website with this link that takes you directly to the section that addresses your exact question. Good hitch, I am very happy with mine.
Rob Payne
Hendersonville, NC
2018 Rockwood Ultra Lite 2304DS, 10K Equal-i-zer Hitch
2007 Toyota Tundra SR5 Double Cab 4WD 5.7L iForce V8
FROG Member since March 2017
09-12-2017, 06:42 PM
At least the 12k. It sounds like your truck is overloaded with this trailer. What is the total weight capacity for this truck?
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
09-12-2017, 06:51 PM
max trailer tow is 9,200 lbs
09-12-2017, 07:04 PM
I have a Rockwood Windjammer, have had the 12k equalizer hitch for 4 years. No problems, great towing.
David Cournoyer
09-12-2017, 08:10 PM
Do you know the max wiggle carrying capacity of the truck? Not the max towing capacity. That is a lot of tongue weight to put on the truck.
Andersen hitch
09-12-2017, 08:37 PM
I would go with the Equalizer 12k or 14k.
09-12-2017, 08:47 PM
I like the blue ox sway pro, newer design and quiet.
I had a 2009 F150 and made a similar trailer change, the blue ox did a good job controlling the sway but it still didn't feel safe so I upgraded to a 3/4 ton, much better
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
09-12-2017, 08:59 PM
X2! On the 3/4 ton. Night and day.
David Cournoyer
09-12-2017, 11:09 PM
I would never use an Anderson WDH on a TT that long.
4pt Equal-i-zer for my TT and 2014 F150 Ecoboost w/Max Tow Package.
09-12-2017, 11:37 PM
Blog: RVroadtripper.com
I had good performance from my A WDH..If you want an honest opinion call Jason at Andersen. If he doesn't think it's a good match he will tell you and tell you why. He has been known to turn away business if he didn't think it was a good fit..
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
09-13-2017, 05:43 PM
GVWR is 9,937lbs
09-13-2017, 08:47 PM
Anybody using Curt TruTrack(1,500lb hitch weight model)? It's only $402 online, so I'm a little worried about quality...thx again...
09-13-2017, 09:10 PM
Tom
For that much TT and a half ton you need at a minimum a Equalizer 4pt or a Blue Ox Sway Pro.
