Originally Posted by Lagman
Is the rec. tube welded right to the main I beams? How far back from the bumper?
I crawled under there. 1st off the new beam is a 3" 'L' welded between the frame side rails. The rec tube is bolted to that then the bracket at the rear is welded to the rec tube and then bolted to the rear frame member, not welded.
The rec tube is ~ 30". There are no other frame cross mebmbers between the new one and the rear one in the photo.
Hope that helps. Hard to get a good pic.
Not sure where the frowning emoji came from. Not intentional.
