Old 07-19-2009, 10:22 PM   #1
Question What does this switch do on my 07 Cherokee 28A+???
I just purchased from a private sale an 07 Cherokee 28A+. After getting it home I was going over the camper from top to bottom. I tested everything!! I then noticed just left of the door a switch? This switch is located behind the trash can access cutout in the kitchen countertop, between the kitchen window and the entrance door. Beside the mystery switch is the antena/cable hookups (w/booster). The switch looks like an on/off switch in a home not the typical on/off switch in RV's. It is the fat retangular style commonly used in homes but it has a neuatral position, an on position and what feels to be a momentary power position? I know this sounds crazy, trust me I have tried it all to determine what this is. The previous owner was cluelesss as well. I took the cover off and found a white power cable going in the top and out the bottom. Looked like the normal white wrapped electrical wire with the positive/negative wires inside. Anybody know what this switch does?
rvthereyet is offline   Reply With Quote
Old 07-19-2009, 10:48 PM   #2
Is this a fifth wheel? Could it have been a ceiling fan switch and some one removed the fan? Just a thought , i think someone on here some time ago said they had a regular switch for their fan but i may be mistaken . Also Welcome to the forums
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 07-20-2009, 06:23 AM   #3
It might be for an outside power outlet up near the awning if you have one. On my Wolfpack theres a switch near the door to turn on and off the outlet for awning lights. That way you can control them from inside.
krabid is offline   Reply With Quote
Old 07-20-2009, 07:43 AM   #4
endeavor to persevere
dlstewart01's Avatar
There are two switches on my Roo by the door. One turns on the outside light and the other turns on the light over the sink. Now the sink light has to be on for this swich to work.
Don
3/5 Cav, C Troop, BlackKnights, Vietnam, 1969
dlstewart01 is offline   Reply With Quote
28a
