Old 03-27-2012, 09:25 AM   #11
Wanna Be Camper
SaskCampers's Avatar
That is exactly what the floor in our Edgewater did after the 1st winter. I would guess in this case it may go flat when it gets warmer but they repaired ours under warranty as I mentioned earlier.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
SaskCampers is online now   Reply With Quote
Old 03-27-2012, 09:39 AM   #12
Rugged Brown's Avatar
If you are still experiencing freezing temperatures, I wouldn't do anything until your temperatures rise. Pushing on frozen linoleum will likely result in cracking. Wait until it warms up when there is more flexibility. Basic characteristics of vinyl/plastic is expansion and contraction in changing temperatures.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 03-27-2012, 05:40 PM   #13
fast murray's Avatar
Hopefully its the temperature as I don't use it when its cold. I can push down on the wrinkles so hopefully the floor is ok. When I run the slide in I can see it rise up slightly before coming in but I'll get down and watch it. I'd really like to not refloor the camper as I've got some other things that need done this spring.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 03-27-2012, 05:46 PM   #14
RonLynnJr's Avatar
I had this happen to me in my Prowler but it was caused by a leaking sink drain.
Ron, Tami, Annette, and Ron III
United States Coast Guard Active Duty
2011 Salem 28BHSS / 2004 Dodge 2500 Cummins
2012 reserved/camped (17/4)
RonLynnJr is offline   Reply With Quote
Old 03-29-2012, 08:25 AM   #15
The flooring expands and contracts with temp changes, except at the edges where it is fixed in place by walls or furniture. Usually, the flooring is NOT glued down in RVs due to this phenonmenon, so as to inhibit tearing damage to the material. I notice that my flooring is loose when very cold in the RV and returns to normal as things warm up.
Big Vic is online now   Reply With Quote
Old 03-31-2012, 09:49 PM   #16
Well, it was 80 degrees here today and the floor is still wrinkled. I think the slide may be a little lower in the middle but I'll have to do some more checking. I can't imagine what would have happened to it but maybe it just needs more time to mellow out.
2004 Wildcat 28BH
