Old 03-25-2012, 04:17 PM   #1
fast murray's Avatar
What Happened To The Floor?
I ran our slide out today for the first time since last fall and the linoleum looks like it pulled out from under the carpet somewhat and is now loose. Why would this happen and can I fix it without some major floor work? It's almost like the glue let go or something.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 03-25-2012, 04:35 PM   #2
Pictures would sure help!
Old 03-25-2012, 04:40 PM   #3
Malco's Avatar
Did you notice if the floor was wet.The glue used for residential vinyl flooring will deteriorate if the substructure it is on is allowed to remain saturated for any length of time.Not sure if the flooring in trailers is even glued down but if so it could be water got in around the slide and saturated the plywood.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 03-25-2012, 05:13 PM   #4
Wanna Be Camper
SaskCampers's Avatar
How cold does it get where you live and is this the first winter for your unit? If it is the 1st winter, it can sometimes be expected in clod climates. That happen to our last trailer and it was repaired under warranty.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-25-2012, 05:31 PM   #5
It gets plenty cold here but it's around 50 today and it was close to 80 last week. I don't think the floor was wet at all and I checked on it every couple of weeks through the winter. It's a 2004 but we just got it last summer. Maybe when it warms up it'll flatten out?
2004 Wildcat 28BH
Old 03-25-2012, 05:47 PM   #6
Here's some pics:
It's difficult to see in the pics but the white line on the right side of the 1st pic is supposed to be under the carpet.
2004 Wildcat 28BH
Old 03-26-2012, 08:04 PM   #7
If it isn't glued down, will vinyl flooring expand and contract with drastically changing temps?
2004 Wildcat 28BH
Old 03-27-2012, 06:21 AM   #8
Malco's Avatar
In residential,the cheaper vinyls that are meant to be glued will change quite a bit dimensionally with drastic temperature swings.If it is not glued then this is most likely your problem.hopefully it will lay flat for you in the warmer weather.In the meantime you should avoid walking on it in the cold temps as it is likely to crack if flattened out while cold.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
Old 03-27-2012, 08:32 AM   #9
Crusader's Avatar
Fast Murray, Most flooring is glued along the outside parameter only. I would check to see if the slide is clearing the floor as it comes in. To me, it looks like the floor is being stretched by the slide. Especially if its only doing it on the slider side of the floor.
Crusader is offline   Reply With Quote
Old 03-27-2012, 08:37 AM   #10
Herk7769's Avatar
Another idea.
Push on the hump in the flooring. Does it "give"?
If so it could be the flooring pulling away from the composite wood substrate as mentioned previously.
If it feels "solid" under the hump; I would lean toward water intrusion deteriorating and expanding the engineered wood.
HAM CALLSIGN - KC3FFW
