05-29-2018, 05:40 PM
What is the stuff Im thinking of
I know vague right.. I took the cover off of our TT this past weekend and in one spot the cover stuck to the roof, It was on a seam and the white caulking type stuff pulled off, kind of like bubble gum.
It didnt leave a open hole in the roof seam, but I do want to buy some more of this stuff and cover what was taken off. Can someone help me make sure I buy the correct stuff, what is the correct caulking called? Thanks
2012 Ram 1500 Crew Cab Sport
2018 Grey Wolf 22MKSE
05-29-2018, 05:42 PM
Dicor self leveling
05-29-2018, 05:54 PM
Originally Posted by donniedu
Dicor self leveling
X2, Dicor self leveling.
2015 F-250 FX4
05-29-2018, 06:01 PM
Dicor self leveling
Yep, thats it! Thank you.. Now I've got to find a place to buy it from. At least I know what to ask for now.
05-29-2018, 06:32 PM
Now I've got to throw a curve ball in. Searching for the sealant I ran across Eternabond Tape
https://smile.amazon.com/gp/product/...KIKX0DER&psc=1
The seam appears to have a aluminum type clip/hold down and then the white roof material. Its located right on the front curve of my TT. So which one would be better to use? The Dicor or Eternabond?
05-29-2018, 06:45 PM
Just as confused as you
http://www.eternabond.com
Eternabond definitely. Many others, myself included, apply Eternabond over all the seams and anywhere there is dicor as preventive measure. Just apply it right over the dicor. It's warranted for 10 years when applied as directed.
Some don't wait a year to apply it. Some even apply it so it covers the fasteners along the sides. Just fold it over the trim and avoid covering the gutter.
AFAIK everyone who have used it is very happy with the results.
One thing to keep in mind is once it touches any surface it's hard to remove.
Richard & Jill
05-29-2018, 07:16 PM
Originally Posted by Scrapper
EternaBond
X2, Eternabond it once and forget about Dicor.
2015 F-250 FX4
05-30-2018, 12:39 PM
You can buy it on Amazon.
05-30-2018, 02:42 PM
X3 It is worth the extra work to have peace of mind.
Radi-cool Rik
05-30-2018, 03:00 PM
Leads to another question
EternaBondOne thing to keep in mind is once it touches any surface it's hard to remove.
That leads to another question. Our 2007 Cherokee has a slideout with two flat skylights. Each appears to be a 20" x 20" piece of 3/16" polycarbonate taped on all four sides to the EPDM slideout top. There might be two layers of polycarbonate, can't be sure.
The polycarbonate has yellowed and crazed and cracked, and the Eternabond is cracking in a few spots. I want to remove the old polycarbonate and Eternabond and replace it. What is the best way to remove it? Can I heat it slightly with the heat gun without damaging the EPDM?
Larry
05-30-2018, 03:02 PM
Often cheaper on eBay
Often cheaper on eBay.
Larry
05-30-2018, 03:10 PM
And don't forget... those with Alpha TPO roofs should use Alpha brand sealants.
We've seen reports of Dicor bubbling the TPO material and there have been past discussions on this with photos of the bubbling.
BTW... the Super Flex sealant sold by Camping World is rebranded Alpha 1021 specifically for sale at CW. This was verified by Alpha in an email to me.
05-30-2018, 05:34 PM
I found the Eternabond cheapest on Amazon last night. Ordered it and got it today! I gotta love Prime! Thanks for the help everyone.
05-31-2018, 07:52 AM
Another question
I've got a leak around the chimney flashing on my brick house. Can I use Eternabond to seal that leak? Has anyone used it on a brick and morter house?
2020 Rockwood 2608BS Ultra-Lite
Eaz-Lift 48703 Trekker
2018 Dodge Ram 2500 Cummins Diesel
05-31-2018, 08:04 AM
Not on brick or mortar
If you mean sealing across seams of the galvanized steel, sure.
I don't believe it would adhere well to brick or to mortar. The surfaces are porous and non-uniform (not smooth), so there wouldn't be 100% contact. And mortar isn't good under tension--the sandy surface would pull away with the tape.
Larry
05-31-2018, 08:11 AM
Larry
I have used heat to soften and have been able to remove, but it is a pain. Just be careful with the heat as to not melt anything that shouldn't be.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
