Old 08-02-2016, 01:59 PM   #11
KyDan's Avatar
Originally Posted by MOODMAN View Post
The video says to use a 7/16 bit, but isn't clear what they mean by that. What KIND of 7/16 bit???
There's a big difference between a socket and a bit.
My Solera awning has a 7/16 hex shaft under the rubber cap. That means a socket
driver that can fit a drill motor or a ratchet and a LOT of time.
In my case it also means at least a 6' step ladder. Currently I'm carrying a telescopic ladder to reach the roof for cleaning off slide before closing. Now I suppose I need a step ladder as well..... it's hard to cover all contingencies.
Peace!
Dan & Rita D
Blue Ox WD hitch
2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-28
Old 08-02-2016, 02:00 PM   #12
Left Coast
Carry both?.......
Sent from my XT1585 using Tapatalk
Old 08-02-2016, 03:45 PM   #13
Those little motor cost about $ 375.00
goots is offline   Reply With Quote
Old 08-02-2016, 03:48 PM   #14
Originally Posted by SailorSam20500 View Post
I recently saw a post about using a GM power window motor to replace a failed awning motor. It was supposedly a LOT lower price than getting a direct replacement. The post may have been on the IRV2 forum.
Will NOT work on a Dometice/A&E awning. You can get a Dometic/A&E motor on ebay.
Old 08-02-2016, 04:19 PM   #15
SailorSam20500's Avatar
Another piece of information for future use. Learning something every time I log on here..
Al
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 08-02-2016, 04:35 PM   #16
I would stick with getting the right part made for it
Old 08-03-2016, 05:52 AM   #17
Wolverine 1945's Avatar
Originally Posted by BooBoo23 View Post
Here is the manual that gives directions for manual operation of a Dometic electric awning.
http://www.primetimerv.com/download/...-UserGuide.pdf
And if your Dometic power awning did not come with a Pull Strap ???
Wolverine 1945 is offline   Reply With Quote
Old 08-03-2016, 06:04 AM   #18
Pickin' & Campin'
Mine was in the bag with the manuals.
Days Camped: '15=22 '16=46 '17=30
Old 08-03-2016, 06:09 AM   #19
I was wondering about that,,, I will need to check that out !!!
On our old Manual Awning you had to use Pull Strap every you put your Awning out or in !!!
Old 08-03-2016, 07:51 AM   #20
KyDan's Avatar
Time for some clarification- feel free to correct me but so far this is what
I have...
Dometic/A&E power awnings come with an emergency pull strap. IF you have
motor failure with the awning out you can install the pull strap by sliding it
in from one end and then while someone holds tension on the strap you
remove the screw on the end of the tube. With the screw removed the
strap can be eased up allowing the spring to roll up the awning much as
you would do with a manual awning. Then a trip to the dealer to fix the
motor and replace the screw.
Solera/Lippert awnings do not have an emergency pull strap. They have a
rubber cap on the top of the motor case. Removing the cap reveals a 7/16
hex shaft. You can use a drill motor with the appropriate socket to run
the awning back in.
Apparently Solera awning owners can purchase car window motors that
will fit the Solera awning. These can be found on Ebay for as low as $32
including shipping! MUCH cheaper than "official" parts from Solera.
The car part does not have the emergency hex shaft so if that one
eventually fails you would not be able to run in the awning.
ALSO- I was mistaken in some of my previous posts where I stated
the Solera awning has gas struts and not a spring. FRF contributor
Teamfour has done this swap and he told me there is a spring.
Once the motor cover is removed you can drill a hole in the large gear
and stick a punch or something similar thru the large gear
effectively locking the spring.
Then you can do the motor swap.
Solera continued-- if you visit Ebay and search dorman # 742-141
you will find several vendors selling the auto part that apparently fits the Solera awning.
Also see this thread for more discussion about the Solera
motor swap- Cheap LCI awning motor replacement
I realize this type of DIY is not for everyone but some of us like to tinker
and saving a couple hundred buck$ is good incentive. Don't attempt anything
like this unless you feel comfortable
working on a ladder as well as working with spring tension which could hurt you if it got away!
Be careful out there!
Peace!
Dan & Rita D
Blue Ox WD hitch
awning
