Old 06-28-2011, 12:45 PM   #51
Send a message via Skype™ to toshu
Hmmmm....then it might be the MW...unfortunately the house unit cannot be tested. The generator has started the ac but only with a full battery.
-2009 Ford F-150, SuperCab w 8 ft bed
5.4L Screw, 3.73 rear, 8200 GVWR
-2011 Rockwood 2604, 2x6V Interstate U2200 batteries,Yamaha 2400 genny
-2011-23 nights
toshu is offline   Reply With Quote
Old 06-28-2011, 01:17 PM   #52
Herk7769's Avatar
Please remember that not all microwaves are created equal no matter what Orson Wells says. Some are more equal than others. A 900 watt microwave like in my Flagstaff is a very different creature than a nice 1800 - 2000 watt full size unit.
HAM CALLSIGN - KC3FFW
Old 06-28-2011, 05:44 PM   #53
Fire Instructor's Avatar
Now that sounds even STRANGER! To the best of my knowledge, the entire air conditioning system as 120v AC, and should have nothing to do with the DC (battery) system. Do you have another 1500 to 2000W+/- apppliance that you can to start with the generator? A small window air conditioner? A small 120v compressor, a big (Margaritta style) ice shaver/blender?
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 06-28-2011, 06:29 PM   #54
Oilmaggott's Avatar
For those having trouble starting their generators with the Yamaha 2400 I would highly recommend installing a hard start starting Cap in the unit. Most of the new FR units are shipped with only a run capacitor not a starting capacitor. The units are already set up for it and it even has it in the schematic inside the case. The best choice is the Supco SPP6. It will give the compressor a 500% increase in startup Torque. Very cheap..only two wires to plug in. Trust me on this one it will fix your problem.
Oilmaggott is offline   Reply With Quote
Old 06-28-2011, 06:43 PM   #55
Oilmaggott's Avatar
Check this link. It is where I originally got the idea....
http://www.modmyrv.com/2009/05/27/rv...tart-capacitor
Old 06-28-2011, 07:39 PM   #56
Rugged Brown's Avatar
MY 2000 watt Yammy runs my MW just fine. It will also run the AC too if I want.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 06-28-2011, 07:46 PM   #57
yes it is strange and is based on limited experience with the TT and Genny since I have to store the TT on a lot. I will hopefully be back home this week and will bring the TT home to play with it and the Genny, MW and AC.
Heck, I might even drive with it to Assateague for the day
-2011-23 nights
Old 06-28-2011, 07:47 PM   #58
my 2011 FR is equipt with an Airxcel AC. Is that what you are talking about?
-2011-23 nights
Old 06-28-2011, 08:07 PM   #59
Oilmaggott's Avatar
We had a 2010 Surveyor 189 TT with a Dometic 13500 AC and the Yamaha 2400 would not start the AC until I installed the Hard Start Cap. After the install it ran just great. Would even start the AC after I shut it off and restarted with high head pressure. I was even able to run the MW with the AC running. Our Coleman / Fleetwood popup has a Mach II AC and the Yamaha will start it just fine without a CAP.
We just bought a new 2011 Wildcat 322RK with a 15,000 BTU AC. Generator will not start it. Just installed a second AC, 13,000 BTU in BR and generator will start and run it without a hard start CAP. I have already ordered CAP's for both units and will let you know if the Yamaha will start the big unit, have read on the web some have good luck doing it. But have the small unit that runs great on the genny now for dry camping.
Old 06-28-2011, 08:22 PM   #60
So how does one know which wire to pull off to wire this gizmo into the system?
Fire Instructor
