Old 09-18-2010, 11:40 AM   #11
Iggy's Avatar
Great subject and information.
I plan on adding some grease to my wheels. Just finished a 1,600 mile trip.
I hope I don't need 3 tubes before I see fresh stuff.
Iggy is online now   Reply With Quote
Old 09-18-2010, 11:58 AM   #12
Mr. Black's Avatar
My number one piece of advice for those that plan on putting more than about two pumps into each hub? or purge lubricating is to take the time to jack each wheel up a half inch or so. This way you can spin the wheel which drastically helps the grease flow out the outer bearing which relieves pressure on the inboard seal. Also don't recommend greasing below 40-50 degrees outside. And last but not least, pump fairly slow. These steps will ensure a good greasing of both bearings and keep you from ruining your seal which will more than likely ruin your brakes.
Seal blow outs are what gave these types of greasing systems a bad reputation when in reality it was just operator error most of the time.
I recommend purge lubrication over just putting a couple pumps a year in but conditions will very.
Also, I recommend after purge lubrication wait a few hundred miles and go in and remove the excess grease that has flowed out of the outboard bearing into the dust cap. This will keep grease from weeping out of the cap and making a grimey mess over time.
Hope this helps and there is a ton of google information, good, bad, and ugly about this subject.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 09-19-2010, 04:42 PM   #13
jimh's Avatar
if ur bearings are like mine on the 2002 cardnal 5th wheel, ie u have to remove a plugg to access the greese cert which is tapped into the end of the axel, u won't have to worry abt overpressuring the system. the greese will simply come out the front. if u have buddy bearings (spring loaded that keep pressure on them, u will).
on mine the greese travels thru the axel and comes out at the rear bearing and travels back to the front. if u pull the rubber protector and see the wheel nut, urs is like mine.
by the way, synthetic greese or oil is still from petroleum base. it has been alered though. we useto take asphault and crack it in a hydrogen atmosphere and produce synthetic crude oil among other things.
while ur down there, check the bolts for tight or missing that attach the back plate to the axel. i had those come out on one wheel recently. i had never checked or even thought to check them in the past. now they are part of an annual check list. put a wrench on the back side and see if u can turn them. u don't have to remove the drum (unless they are loose or missing).
jimh is offline   Reply With Quote
Old 09-19-2010, 04:47 PM   #14
Mr. Black's Avatar
Gonna have to agree to disagree on that one. In theory yes, you are correct about the systems operation, but then humans came along.
Many people have pushed grease out the back with this system.
Steve
Old 09-19-2010, 11:07 PM   #15
jimh's Avatar
after having mine apart, i'm wondering how? any pumping u do goes next to that seal. they must have encountered something pushing thru the bearings. the greese travels thru the axel to the back bearing. are u sure they weren't using the buddy bearings? it's easy to see how that could happen with them. perhaps the answer would be to pump slowly and allow the grease to move thru.
rotating the wheel would distribute the grease thru the bearing and allow the grease to distribues with less pressure.
i pumped mine for the first time sense i bought it (2002) before going out the time before last and experienced problems with the brakes. i thought i had pumped thru the seal. when i got home is when i found the loose back plate. it spun around and severed the wires to the rear axel. when i took the asembly appart, i didn't have any grease in the brakes.
you might say i lucked out to not have problems after going 8 yrs without adding grease.
Old 09-20-2010, 06:59 AM   #16
jimh's Avatar
looks like murphy is alive and well in the rv industry.
Old 09-20-2010, 07:41 AM   #17
MtnGuy's Avatar
I do as Mr. Black does.....raise the wheel and turn while adding grease to prevent the rear seal from leaking. And never use any type of grease gun that is not manually operated.
I hand packed the bearings in my Trailmanor, but have not done so in my Surveyor in 2 years of ownership. I did use the EZ lube hubs to add grease, and then wiped the old grease out to give it a little air space in there. I hope I don't get bit by this method, but I don't intend to hand pack the bearings unless a hub starts getting warmer than the others. I always check the hub temperatures at road breaks, comparing each hub against the others. If 1 hub continually runs hotter, then I will dissemble that puppy to see what is going on.
Old 09-20-2010, 02:42 PM   #18
jimh's Avatar
i wonder how many problems have been created by adding the certs to the axel ie think abt how often joe citizen repacks the wheel bearings on the average viehicle and how few failours their are...
the last time i repacked a wheel bearing was in the 70's and the gresae was kind of fiberry. it wasn't what u would find in a tube. the grease that was in my trailer axel looked the same as what i pumped in.
Old 09-22-2010, 06:47 PM   #19
backin15's Avatar
As mtnguy said, do not use a grease gun powered by an air compressor - dont ask me how I know!
backin15 is offline   Reply With Quote
Old 10-30-2010, 05:58 PM   #20
kz08h5's Avatar
After reading these posts I realized that my bearings have not been serviced since I bought the trailer in Jun of 09. I am surprised that I have not been stranded on the side of the road. The grease fittings would not accept grease and of course made a mess. I removed the grease fitting to see if grease was going through it and it wasn't. Something was wrong with all of them so all were replaced. I used two 3 oz. tubes of grease on 4 hubs. 3 of the fittings were less than hand tight and one had come out completely. I hope I am not too late with the grease.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
