Old 04-13-2010, 05:09 PM   #11
Originally Posted by kvtaylor View Post
When using those EZ-Lub hubs. Go slow with the grease. A fast jerk on the grease gun and you will have grease coming out the back thru the seal.. When we towed TTs and 5th wheels, i had them packed every year at a camping World somewhere. It was cheap enough to know the bearings were cleaned and repacked and new seals were installed. I did use the EZ-Lubs on the 5th wheel (Montana) but only spareingly. On my boat trailer, I used the EZ-lub hubs and packed them too much and blew the seal on one wheel.
Good tip! Also if you do it on a very warm or hot day that grease will flow easier, and if the hub is hot that will help too.. Lay out a tube of grease on the asphalt in the hot Texas sun in August and it is almost liquid after an hour or so.
2008 Georgetown 315DS SE
khager is offline   Reply With Quote
Old 04-13-2010, 08:03 PM   #12
backin15's Avatar
I did use an air powered grease gun on my last camper with EZ lube hubs and always had grease all over my wheels after a trip. I did not have any from the rear seals. Maybe it was the air gun that caused the problem. I don't want to make the same mistake on the new Flagstaff so I will get a manual gun. I asked how much grease to pump in at the PDI and he really couldn't give me an answer. What is the guideline? I like to be generous with grease and I thought overgreasing is what caused grease to get on the wheels.
backin15 is offline   Reply With Quote
Old 04-14-2010, 06:46 AM   #13
KyDan's Avatar
I believe that the EZ lube hubs are drilled so the grease goes in
the end of the spindle and comes out behind the rear bearing between the rear bearing and the seal.
Then it moves outward thru the rear bearing and then
thru the hub and finally thru the outer bearing
and appears as excess oozing out around
the outer bearing washer and nut.
This is a pretty good design as it forces out most of the
air and more or less completely fills the hub and bearings.
If done correctly and SLOWLY it should not blow out the rear grease
seal as the excess is vented out the end around the grease
fitting. Stiff cold grease or grease shot from an air powered grease
gun can be forced out the seal as it cannot pass thru
both bearings and out the front end fast enough.
In my case, after I disassembled a couple wheels I discovered
that my spindles are drilled and tapped for this grease fitting in
the end but it was not installed.
They (Forest River) saved all of 2 or 3 bucks by short changing
my trailer.
All it needs is 4- 1/4 28 grease fittings and 4 grease caps with
the removable rubber center. These can be bought for a few
bucks at etrailer.com
I'll put in a temporary grease fitting and fill each hub thru the end of the spindle.
Once grease is all the way thru the hub and coming out the front
bearing, I'll re-install my bearing buddy caps and be done
with it.
Well yeah, there is still that little chore of adjusting
all 4 brakes
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-14-2010, 09:30 AM   #14
cat1956's Avatar
Is all wheel bearing greese compatable?If not what greese should be used with factory packed bearings.Thanks
cat1956 is offline   Reply With Quote
Old 04-14-2010, 11:46 AM   #15
KyDan's Avatar
Al-Ko "owners manual" says to use lithium #2 grease.
This should work for most axles.
Old 04-14-2010, 12:17 PM   #16
MtnGuy's Avatar
Originally Posted by mtnguy View Post
Now a somewhat silly question for y'all: Does the color of the grease make any difference??? I can't remember right off which is which, but the wheel bearing grease that I have is red (or blue) and the grease in the hub is blue (or red).
I posted this question earlier, so I thought I would tag it on the previous post. Does the color of the grease indicate anything special ??
Old 04-14-2010, 02:21 PM   #17
KyDan's Avatar
Not that I know of.
Different makers use color dyes to show their grease.
Both my last 2 trailers which had different brand axles said
to use
Lithium complex #2 grease.
I have 2 different brands and one is sorta red and the
other is sorta blue.
They all wind up kinda black after a few thousand miles!
Old 04-14-2010, 03:02 PM   #18
MtnGuy's Avatar
Thanks KyDan. I have lithium #2 grease.
Old 04-14-2010, 07:15 PM   #19
backin15's Avatar
I found this on the Open Roads forum:
From the Al co site:
Grease
Use a high temperature, automotive type wheel bearing grease
produced by a reputable manufacturer. The soap type should be lithium
complex or equivalent. Use NLGI Grade 2 product
with a minimum dropping point of 440o F.
Dexter is a little more specific:
Wheel Bearing
Lubrication Specifications
www.dexteraxle.com
GREASE APPLICATIONS
Specifications
Thickener Type Lithium Complex
Dropping Point 215 degrees C (419 degrees F) minimum
Consistency NLGI No. 2
Additives EP, Corrosion & Oxidation Inhibitors
Viscosity Index 80 minimum
Approved Sources
76 Lubricants Company 76 Multiplex EP
76 Multiplex RED
Citgo Petroleum Corporation Lithoplex MP #2
Lithoplex CM #2
Exxon Company, USA Ronex, MP
Kendall Motor Oil (Division of Witco) Kendall Super Blu L427 Grease
Mobil Oil Company Mobil Grease HP
Mobilith AW 2
Mystik Oil Company, Inc. Mystik JT-6 Hi-Temp Grease
Red Lithium Complex EP No. 2
Oil Center Research of Oklahoma Liquid-O-Ring No. 167L
Pennzoil / Quaker State Company Synthetic Red Grease
Shell ALBIDA LC 2
Royal Manufacturing Company Royal 98 Multi-Lube EP #2 Lithium Complex
Chevron Texaco Chevron Ulti-Plex Grease EP NLGI 2
Texaco Starplex Moly MPGM 2
Valvoline (Division of Ashland Inc.) Valvoline Multi-Purpose GM
Old 04-26-2010, 02:56 PM   #20
[QUOTE=KyDan;42881]I believe that the EZ lube hubs In my case, after I disassembled a couple wheels I discovered
my trailer.
I found the same thing the other day when i pulled the wheel on my 28a+ as I also found the castle nut to be really loose the keeper is there but man too loose for my liking I wiggled the back wheel and found it wobbly I know what i am doing this weekend.My spindle is also tapped but no fitting is it good to go to just add a fitting if so I will.I also thought the same kinnda cop out on forest rivers or lipperts part for .25 grease fittings
Santaclause is offline   Reply With Quote
bearings
