Old 08-19-2014, 02:25 PM   #1
wplate's Avatar
WhProcedure to clean air conditioner filter?
Over the summer I tried washing my air conditioner filter under the sink with water and a sponge. Unfortunately all it did was get the dust all muddy and gross inside of the filter.
An RV shop guy suggested to me when I bought the replacement filter to wash it using soap and water.
How did you clean your air conditioner filters?
Name:	ImageUploadedByForest River Forums1408476316.174939.jpg
2013 Sunseeker 2860DS
2014 Jeep Wrangler Unlimited
wplate is offline   Reply With Quote
Old 08-19-2014, 02:29 PM   #2
BiigDaddy's Avatar
I use the outside shower sprayer and hot water... At least it keeps the mess outside. Compressed air would be better, but we were camping in a dusty spot.
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 08-19-2014, 02:41 PM   #3
Kaadk's Avatar
I just rinsed it using one of the taps at the Rally. By using a tap directly I was bypassing my pressure regulator and hitting it full blast. Seemed to do the trick.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 08-19-2014, 02:43 PM   #4
Camper Less Camping
Cajun Po-Boy's Avatar
I first rinse it out with hot water to remove all the dust particles, then I hand soak in a mixture of Dawn dish washing liquid & warm water in a sink, rinse and squeeze out excess water. Hang to dry before I reinstall in camper
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-20-2014, 04:03 PM   #5
I have found that if you hang them, sling them, or hold them by one end while spraying they can stretch and will not fit right when you go to put them back in.
I use the plastic filter cover to support it horizontally while I spray it. then turn the filter over and rub it some to work the dust in to balls which spray off easier. its not completely clean but its a whole lot better than it was.
I use the plastic cover to lay it on and place it in the sun to dry
bama29fan is offline   Reply With Quote
Old 08-20-2014, 06:47 PM   #6
Timex's Avatar
Go to WM and buy a pack of the filter material and cut to the same dimensions as the original filter. This way you will be assured to having a clean filter with no tears in the material.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 08-24-2014, 07:34 AM   #7
Bradlo3's Avatar
Rinsed mine in the sink, then ran thru the dishwasher. Good results.
Bradlo3 is offline   Reply With Quote
Old 08-24-2014, 07:36 AM   #8
fonzie's Avatar
Dish soap and hot water, then rinse and towel dry and install back.
Fonzie
Old 10-03-2014, 09:44 PM   #9
Sharon455's Avatar
I vacuumed ours using the brush attachment, then washed in warm soapy water in house sink. Wrapped in kitchen towel to wick away water, then reinstalled.
Happiness is just a ride away!
Sharon455 is offline   Reply With Quote
Old 10-03-2014, 10:18 PM   #10
deartruc's Avatar
After cleaning or replacing...try dryer sheets between the cover and the filter. Adds a little "bounce" odor and you throw away when dirty. Also, the filter media is dark grey and not easy to spot when dirty, dryer sheets are lighter and you can see right away when they need to be replaced.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
air conditioner
