Old 06-14-2016, 11:51 PM   #1
Wildcat Maxx rear electric stabilizer
No 12 VDC power to LCI electric rear stabilizer. Lippert bulletin 0025 shows a minimum 20 amp fuse or breaker( customer supplied) which is somewhere on the chassis. Anyone know where it could be located?
wwc1921 is offline   Reply With Quote
Old 06-18-2016, 08:23 PM   #2
Start by checking the fuse panel ---- mine were all labeled but I don't recall if there was a fuse for the rear stabilizer.
bruceatlam is offline   Reply With Quote
Old 06-19-2016, 08:48 PM   #3
Found two 30 amp fuses located on the left side railings about 30 " in back of the battery disconnect switch. They are for the the front and rear electric stablizers. Thanks for the reply though.
cat, electric, wildcat
