Originally Posted by Bama Rambler
Are the evaporator coils freezing up causing it to shut down?
Which A/C and thermostat do you have?
I'm als curious how they replaced all the duct work? Did they pull the ceiling down to do it?
Originally yes it was freezing up that’s how they found the crushed duct work. The removed the ceiling above master bedroom and found crushed tubing in vent above bed and the second vent in hallway had enough tubing extra to reach the front of the camper . It is now moving a ton of air .
I have not climbed up there yet to see if it is freezing up.
I have the three button domestic T-stat 3316350.00
Both front and rear T-star are mounted side by side in hallway .
