Old 06-06-2013, 02:18 PM   #1
LJ_Sha's Avatar
Winegard antenna issue
We recently purchased a 2008 5th wheel and took it out for the first time. The camper was only used 6 or 7 times by the previous owner. The issue I'm having is with the connectivity with the antenna to TV. I pushed the button on, it showed a green light, behind the TV and put the antenna up. I placed the TV on channel 3 and conducted a channel search. The search came up with 14 channels which was great for a split second. A picture with sound came up then froze. The TV then showed no TV Signal and all channels were gone. I attempted the channel search again with negative results. What's the issue / problem? Thanks
LJ_Sha is offline   Reply With Quote
Old 06-06-2013, 03:05 PM   #2
Is the green "booster" light still on?
If it is, it sounds like you've got a bad wire, bad antenna amp, or bad control behind that green light.
Old 06-06-2013, 03:14 PM   #3
Herk7769's Avatar
Did you use "air" when you did the channel scan?
Did you use an optimal heading to the transmission towers when you did the scan?
Is the TV Digital ready? You may need to buy an analog to digital converter to get your TV to work with the new signals.
Name:	Antennaweb Roadmap Wide angle.jpg
ID:	32453   Click image for larger version
Name:	Antennaweb Satellite at Camper.jpg
ID:	32454   Click image for larger version
Name:	Antennaweb Satellite Wide angle.jpg
HAM CALLSIGN - KC3FFW
Old 06-06-2013, 03:17 PM   #4
LJ_Sha's Avatar
The green light is on the wall plate and does go out when I push it to turn it off. If it's the cable how would I replace it? Its my understanding it goes from the antenna to the wall mount plate.
Old 06-06-2013, 03:21 PM   #5
Herk7769's Avatar
Whoa. You need to leave the switch ON (green light on) the entire time you are using the roof antenna. It is the coax switch (that switches between the roof and the park's cable) AND the power supply to the amp located in the roof antenna's white box.
Turning the switch off disconnects thr off antenna from your TV.
Here is your manual.
Old 06-06-2013, 03:21 PM   #6
LJ_Sha's Avatar
herk7769...... Not sure what you mean by "air" but we never had a chance to turn the antenna. The picture that did show for second or two was extremely clear before it froze and went out. The TV is digital ready from what we were told but I will hook up a box just to make sure.
Old 06-06-2013, 03:22 PM   #7
I would just check all of the cable connections to make sure they are tight. If they are, then about the only way to debug this is to try replacing components, which you probably won't be able to do.
Old 06-06-2013, 03:24 PM   #8
LJ_Sha's Avatar
I only turned off the switch when the TV stopped working and no channels were found.
Old 06-06-2013, 03:26 PM   #9
Herk7769's Avatar
"Digital ready" is not a digital tuner! You need a seperate analog to digital tuner to make a digital ready TV digital. Amazon.com: iView 3500STB DTV Converter Box: Televisions & Video
You need to turn the antenna FIRST to the direction of the towers; THEN scan for channels.
Old 06-06-2013, 03:27 PM   #10
Herk7769's Avatar
LJ, how about a photo of your TV.
I am thinking you are trying to receive a digital signal on an analog TV.
