Old 05-05-2009, 09:27 AM   #11
Those of you with the fridge vent in the way, it looks to me like the 3 foot (est.)aluminum "mast" that raises up the antenna could be bent to conform with the vent, if it isn't right on top of the vent upon lowering. I wouldn't think that would interfere with the signal.....just a thought....I wouldn't want to climb up un the roof every time I went camping, A.) not too safe; and B.) might make roof leak; and C.) not designed for that!
Myself, I bought my unit for EASY and convenient camping trips! Randy
Old 05-06-2009, 07:57 AM   #12
KyDan's Avatar
My antenna comes down right beside the fridge vent.
If I put on the Wingman it will come down on top of the vent.
I'd have to put a SERIOUS bend in my mast to make it miss.
I'll either live with it or turn my mount clockwise about 15 degrees one day.
I don't like adding any extra steps to setup and take down either but we do watch
the tele most nights before bed and very few of the parks we visit have cable.
In the "old days" we could put up with a snowy picture but on digital, you either have
it our you don't.
When the analog signals all stop I think there will be lots of folks out in the fringe areas
that will suddenly find they have no signal they can use.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-06-2009, 09:16 AM   #13
I know exactly what you mean!! Those annoying "digital freezes" as I call them make me change the channel every time! I did notice that on the base of the antenna, it has 2 metal "nesting" tabs that the mast drops into upon lowering. That does seem like it would work to turn the whole shebang a little one way or another to allow clearance of the vent. Good Luck, and HAPPY CAMPING!! Randy (PS...I'm going up on top to see if the wingman could possibly mount to the LEFT side for you guys with this problem.) Will post result later... Randy
Old 05-06-2009, 09:52 AM   #14
KyDan's Avatar
No way. I looked.
Old 05-06-2009, 12:43 PM   #15
hunt4240dw's Avatar
Send a message via MSN to hunt4240dw
Me too ... No way ... My antenna was mounted closer to AC than Randy. I have traded one email with Winegard Tech help about another solution.
David
The Hunts
2012 F150 Ecoboost, 3.55, tow package
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
hunt4240dw is offline   Reply With Quote
Old 05-06-2009, 12:52 PM   #16
KyDan's Avatar
David
Please let us know what they say about this issue!!!
Old 05-13-2009, 09:42 AM   #17
hunt4240dw's Avatar
This is their response ...
You can remove the last element and will still get much of the UHF signal boost. This is not something we recommend but in some cases it is the only option.
Winegard Technical Support
1-800-788-4417
David
The Hunts
Equal-i-zer Hitch
Old 05-13-2009, 10:42 AM   #18
KyDan's Avatar
That's a thought.
In my case I'd have to remove 2 of the elements which pretty much negates the
gain of having it.
Guess I'm stuck removing my booster each trip. At least until I turn my antenna
mount some day.
Thanks for the reply!
