Old 12-12-2013, 10:43 PM   #1
wanderer03's Avatar
Winter living
I'm living in my 5 th wheel year round, I read or heard that if you place a tarp on the ground when you park your unit it will stop some of the cold air coming from the ground , thus making the floors of your unit a little warmer,
Anyone else heard of this or doing this ?
What about moisture problems underneath?
Any suggestions?
wanderer03 is offline   Reply With Quote
Old 12-12-2013, 11:33 PM   #2
Denver, CO
garbonz's Avatar
I can't imagine that making much difference, if you are parked on ground and not concrete and sheath your unit on the perimeter, then it would make some sense in keeping the ground moisture from the underside.
Some winter campers put skirting around the unit to help the underside of the camper hold a little bit of heat and even put a couple of trouble lights down there.
Cold is cold tho, and anyting you do to insulate your unit will help. putting the plastic shrink wrap or celotex etc on the inside of the windows helps if you has single pane windows.
2017 Fuse 23T
Old 12-12-2013, 11:50 PM   #3
Twisty's Avatar
Skirt the unit.
Air is a very poor transmitter of heat.
Any type of outer layer (think 2 pane window) that can be placed on the exterior will help.
Skirting gives an outer layer to the floor.
If it were possible to envelope the RV in a clear plastic bubble it would make a tremendous difference.
Heat moves to cold.
Cold air in motion will strip the heat from the unit.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 12-13-2013, 07:20 AM   #4
NELA
Weezer's Avatar
On our last trip we saw a brand new 5th wheel with a brown tarp over it. We didn't figure it was due to a leak...new RV and no rain in the forecast.
Ahah! the brown absorbs more heat.
(a clue was that the tarp was blue on one side, brown on the other, and they had the brown side up)
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
