Old 10-10-2010, 07:30 PM   #11
Originally Posted by The_Stuff View Post
question. is it a plumbed toilet or is it a chemical toilet?
Uh, good question. I'm assuming it's a chemical toilet. there is a small holder for some blue stuff just above the cassette tank.
fisk is offline   Reply With Quote
Old 10-13-2010, 11:21 AM   #12
Villa Estate 392FLFB
The_Stuff's Avatar
if its a chemical toilet there is no lines to the water tanks etc. its a self sustaining toilet. dad's old dodge maxi van has one of those. threw us for a loop figuring it out to.
not sure if that blue stuff freezes or not. wouldnt hurt to dump the toilet and then fill it with some antifreeze then re-pump it to be on the safe side.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 10-20-2010, 01:01 PM   #13
MikeInColo's Avatar
I'm not sure that cassette toilets are even connected to the RV water system.
MikeInColo is offline   Reply With Quote
Old 10-20-2010, 01:48 PM   #14
f150k's Avatar
We had a cassette toilet and they are not hooked up to the water supply. They have their own supply which you put the blue chemical in, I would drain the blue out ( I have saved it in the past and use next year) and put a little pink stuff. Make sure you run some of the pick stuff into the cassette, to insure it is protected from the cold.
f150k is offline   Reply With Quote
