Forest River Forums
Sunline User Photos
Old 08-20-2011, 07:45 AM   #1
Bilcin's Avatar
Winterizing gray and black tanks
Almost done camping for the seaon. First time winterizing my TT. Is winterizing the gray and black tanks as easy as flushing them out and then filling them with a few gallons of water and add antifreeze?
Thanks,
Bill
Bill & Cindy McKenna
Philadelphia PA
2011 Wildwood 26TBSS
2005 Ford F150 5.4 Triton V8 4x4 XLT
Bilcin is offline   Reply With Quote
Old 08-20-2011, 07:52 AM   #2
Just flush them out and leave them dry. Just make sure they are drained dry, no need for any anit-freeze in the grey or black tanks.
2008 Dakota Sport 4x4
2012 Rockwood 2604
2004 Subaru Baja - DW's go buggy
1970's Rupp Ruppster - my field go buggy at home
42 nights camping 2011, 2012 5 nights camped and 28 reserved
F.R.O.G. member
lindy is online now   Reply With Quote
Old 08-20-2011, 08:38 AM   #3
Actually no need for antifreeze in any of the tanks, including the water heater. Antifreeze is designed to prevent the water lines from freezing in case there is some residual water left in them. Using an air compressor set at about 10PSI pressurize the lines and turn on the faucets one at a time until there is no more water coming out. Take the drain plug out of the water heater tank. Be sure the winterize valves are set correctly and fill the system using the water pump. Done deal.
donn is online now   Reply With Quote
Old 08-20-2011, 08:44 AM   #4
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
I suggest you get one of these for flushing your tank. It makes filling the black tank prior to flushing it very easy. Just open the toilet and drop this in the hole. Gently release toilet flush lever and this will remain in place, water will run and tank will fill. When about full, go outside and open the sewer connection to drain the tank. Repeat several times.
One very patient wife and one furry child who travels with us. Thirty-eight years of trailering and camping, and I still have a blast.
dimurrrw is offline   Reply With Quote
Old 08-20-2011, 08:47 AM   #5
Moderator
mtnguy's Avatar
Now, ain't that the neatest item. When using my spray wand, I usually end up taking off my right shoe and opening the valve with my toes. Many times I have wished for a foot control flush valve. This should solve the problem.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is online now   Reply With Quote
Old 08-20-2011, 08:55 AM   #6
AKA Bluebird
dimurrrw's Avatar
These have been around since day one. Surprised you haven't seen them before. Proof of the old adage about "Give a lazy man a hard job..."
Old 08-20-2011, 10:17 AM   #7
Bilcin's Avatar
Hey, to all those who replied, Thanks for the information and tips!
Philadelphia PA
Old 08-21-2011, 11:38 AM   #8
The Old Man
Willis's Avatar
Thanks,
Bill
Personally, after flushing the black and grey tanks for the season and closing them, I add a gallon of antifreeze to the black tank (the grey tank will get enough antifreeze in it just from filling the lines and traps). I don't think there is any way to know for sure that the tanks are completely dry and I don't want any residual water sitting against the valve areas to freeze. A gallon of antifreeze is cheap insurance.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 08-21-2011, 12:49 PM   #9
Moderator
mtnguy's Avatar
I think 1 important last step is to drain the lines to both the black and gray tank. If any water is left in the lines at the valves, that has more potential to do damage than a little water left in the very bottom of the tanks.
2008 Surveyor 263
Old 08-21-2011, 07:17 PM   #10
j2detroit's Avatar
i have our camper at a perm site we just drain rince with my wirly wand refill and drain a couple times and just lert them drain leaving what ever anti freeze gets in them and leave both valves open for the winter i change the water heater valve over to isolate it from the rest of the system pull the anode rod out and let it drain i put a small peice of screen over the opening and leve it open for the seasond an rv tech told me to do it this way works great
j2detroit is offline   Reply With Quote
» Online Users: 648
121 members and 527 guests
bashby17, Bigjimt, BigR, bikendan, BlakeB, bob7794, boubou, Buffalohunter, Busman1947, bwbarnes, Cafjackracing, campfirefun, CampinQueen, caper, cardinal4fun, Cascade Bob, cgreen1509, cgsparks1, chof16, Cincy6, cory1, Cowracer, cstover, Curiosity, dasimser, davidjb, dec1952, dezolen, dfrauhiger, djorgensen3, donn, dotsonjc, dretired, dtb7811, dunnnc, f1100turbo, Falcon35, fordmantpw, Gene Ross, geo, gljurczyk, go6car, gredmer, gregm59, herdrn, herk7769, hokiecampers, holymoly, Hoo Dad, hotrodj125, JAJ73, jamesroadking, Janet H, jar3316, JENSENRVDirect, JFM-jr, JJones, jlpurdy, jmswms, johnnypal, judy3972, kegoneill, kixonrt66, KKapa, lazyb1626, lbhird, leadfoot, lindy, lowbubba, LuckyMcBRIDE, Mark S, mhbandy, mike54, milw156, mlhalter, mraynie, mtnguy, mtofell, myredracer, NeilM108, outdoorsbound, papap, Phil57, pick, Piston, punkaccountant, rbrandon, realebill, rerger, RGH, ronhanson, rwzahm, sabre5er, savdog, shane1234, shrimper, silverwing, sledhead77, Snowsail, Stank Bait, tallens, Tee, Terier, tmiller, tmmar, Tom47, tracetrimble, Traci, travyp, treadwelll, Triguy, T_LMurphy, ubercamper, vc17, Vette4trcr, vp22er, VTX Al, Warrior, wfmdfm, whj77372, wnytaxman
Most users ever online was 996, Today at 11:04 AM.
Close [X]
