Old 10-09-2014, 05:28 PM   #11
Thanks Tarawander. I am up here in Idaho so it does get cold!
I am aware of the low point drains on the Forest River products but I am not aware of any on my Lance trailer that I am getting rid of. Thanks for the advice and your time to reply. I may upgrade to a 6 gallon compressor only because it is a good opportunity to upgrade what I have!
Gilm2113 is offline   Reply With Quote
Old 10-09-2014, 06:52 PM   #12
Ford Idaho's Avatar
Originally Posted by Brother Les View Post
Be very careful using air pressure. I do not blow my lines out with air. Open all faucets and drain to low area drains. Isolate water heater (drained) and use water pump to fill water lines with RV antifreeze.
I do the same deal, no air just A/F.
Takes about 20 min by myself.
Old 10-09-2014, 08:01 PM   #13
wbdavey's Avatar
Others will disagree, but I don't trust blowing the water out of the lines method. My fear is that water will somehow find a low spot at a tee fitting or something. My fear is the air will blow right by the low spot allowing the water to freeze over the winter.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 10-09-2014, 08:37 PM   #14
deartruc's Avatar
I'm a pink stuff fan. My buddy with a Four Winds he's had forever only uses air and an auto tire dc air compressor.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 10-09-2014, 08:42 PM   #15
BillyBass's Avatar
r u need is one that you pump up your tire that what I use
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 10-09-2014, 08:53 PM   #16
New FR Owner
Coastie's Avatar
Originally Posted by crunchman12001 View Post
You really do not need an air compressor, you can just buy a Winterizing Kit for under $20.
I do blow my lines but also use anti-freeze with the winterization kit that sucks anti-freeze straight from the gallon jugs on the inlet side of the water pump. My unit takes less than 3 gallons.
A small compressor like this is what I use.
The smaller pancake ones like this would work too.
crunchman
+1
Semper Paratus
USCG, Disabled
2015 Grey Wolf 17BH
2001 Ford 4x4 F-250 Crew
Coastie is offline   Reply With Quote
Old 10-09-2014, 08:55 PM   #17
It sounds like their three camps. Those who use air only, those who use the "pink stuff" and those who use both. My plan was to use air followed by pumping antifreeze.
Old 10-09-2014, 09:26 PM   #18
ColoradoRick's Avatar
Wow, great info in here! I've always had my lines blown out by someone else because I never thought my puny 1-gallon compressor was big enough....I assumed you needed one of those huge ones.
And I'm one of those red antifreeze guys, too....it can get 20-below here at 7,000 in the Rockies so don't ever want frozen lines. It does rinse out real well...just put a little bleach into the water in the Spring when rinsing it all out.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-09-2014, 09:36 PM   #19
VinceU's Avatar
Just make sure to allow the air press to build up between blowing each faucet. Use 30-35 psi at the compressor. Blow from top, shower and sinks down to outside shower and drains. Leave drains open on completion.
Old 10-10-2014, 08:47 AM   #20
rsscully's Avatar
Blow all my lines out first and then pump in antifreeze.
rsscully is offline   Reply With Quote
winter, winterize
