Old 10-13-2014, 02:01 AM   #31
Just a member
kandl's Avatar
Originally Posted by Rhoyle View Post
I live in the Great White North where winter temps can get as low as -40 and have done nothing but blow out my water lines for the last 15 years (my wife claimed she could taste the antifreeze even after rinsing the system several times) and have never had a problem. A small residual amount of water in the lines and tanks should be okay as long as your piping is plastic (it does have some flexibility). Be sure to add antifreeze to drains so that the traps are filled.
In the spring all I have to do is hook up the water and go. No flushing lines or tanks😀.
Ditto - and one would be able to spring for a decent compressor for a fraction of what one would spend for all that "pink" over time.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 10-13-2014, 09:37 AM   #32
DaveSchwartz's Avatar
Ditto X2 on Rhoyle's post. I've been doing air-only (and a wee bit of pink for p-traps) for 9 years without a problem. Might take a little longer in the fall but is a whole lot faster getting ready for the first trip in the spring. No flushing, no sanitizing - fill and go.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 10-20-2014, 07:24 AM   #33
Winterizing help - Air Compressors
FR manual says to use compressed air or RV Antifreeze. I don't fully understand why some people use both. Is it based on experience or "gut feeling" or simply "better safe than sorry?"
biznsa is offline   Reply With Quote
Old 10-20-2014, 08:32 AM   #34
ironj's Avatar
The fear of fixing a valve or Pipe is stronger than thier fear of more work!...lol...either method DONE PROPERLY will work....
I drain what I can via reg method (low point and wh plug) then pop on the compressor ....open each line until dry air shoots out , then pour some pink in all yhe drains...
Course its not quite 'arctic' here in west texas. Lol
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 10-20-2014, 01:25 PM   #35
One thing to keep in mind is to use an oil-less compressor or use a filter to filter out any oil in the airlines to prevent contamination of your camper water lines.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 10-20-2014, 01:32 PM   #36
WFD
Silly question...but if I am shopping for an air compressor how do I know if it's oil-less or not?
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-20-2014, 01:53 PM   #37
Most of the inexpensive ones are oil-less. You can get one at Harbor Freight for $50! The ones that use oil have a reservoir for oil and a dipstick.
winter, winterize
