10-09-2014, 04:21 PM
Winterizing help - Air Compressors
I am looking a purchasing an air compressor to allow me to do my own winterizing. Can anyone help me understand how much air compressor I need to buy be able to successfully blow out my system.
I understand that I should not exceed 35psi into the trailer but how much airflow do I need, how big a volume do I need to get the job done. Will one the 'cheaper' 20 gallon direct drive units work or should I look at the more expensive, 30 gallon, belt driven 2 cylinder systems? These units will put out ~4-6.5 cfm of air at 40psi.
Any advice you experts might be willing to share would be greatly appreciated.
10-09-2014, 04:31 PM
I have a couple air compressors, both for construction type work not running so tools. They work fine. Most any compressor will work, but just take a bit longer if it constantly has to run to hold or build pressure. I use a little twin cylinder (no more than 10 gallon) direct drive one that was about $100 from Napa for the camper. Actually, it lives in the fiver basement.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
10-09-2014, 04:35 PM
You really do not need an air compressor, you can just buy a Winterizing Kit for under $20.
I do blow my lines but also use anti-freeze with the winterization kit that sucks anti-freeze straight from the gallon jugs on the inlet side of the water pump. My unit takes less than 3 gallons.
A small compressor like this is what I use.
The smaller pancake ones like this would work too.
crunchman
2015 F-250 FX4
10-09-2014, 04:38 PM
I use an air compressor now but in the past have used a hand pump like I use to use as a bicycle tire pump.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
10-09-2014, 04:49 PM
Air Compressors
JT, Crunchman & Big Paul --
Thank you for the quick feedback, I already have a small 2 gallon compressor that use for my tires and other things around the house. I was assuming that the volume wouldn't be big enough to do the job. It is very similar to what Crunchman linked to. I already have the winterization kit and the hand pump to hit the black tank wash. Even if I do buy a slightly bigger compressor I now know that I do not need one of those monsters in my garage!
10-09-2014, 04:55 PM
Gilm2113,
It would seem what you have will be fine. Glad to help and feel free to ask additional questions if you run into issues.
crunchman
2015 F-250 FX4
10-09-2014, 05:07 PM
Be very careful using air pressure. I do not blow my lines out with air. Open all faucets and drain to low area drains. Isolate water heater (drained) and use water pump to fill water lines with RV antifreeze.
Brother Les
10-09-2014, 05:11 PM
Air compressors
Thanks Crunchman, I have always paid to have it done, but now that I have retired I thought I would give it a try. I have read all the threads on winterization and watched the videos.
We are getting our Lance trailer ready to trade in once our new Forester 2650S arrives mid next month. I am sure I will want to take the new unit out at least once when it comes so I will be prepared to do the new motorhome too once it arrives and before we put it to bed for the winter.
10-09-2014, 05:13 PM
Thanks Brother Les. I will probably start with very low pressure and work my way up but not exceed 30-35psi and then run the antifreeze in to the lines.
10-09-2014, 05:20 PM
You don't need a ton of volume, there's not that much volume to the piping system. If your compressor will blow up a tire at 30 PSI, you should be good. Just do one faucet at a time (don't forget the toilet and outside shower,) and finish with the low point drains. If you live in the South, many people feel that's all you need to do. If you're up North, then antifreeze is a good follow up to prevent any "spring camper opening" surprises.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
10-09-2014, 05:28 PM
Thanks Tarawander. I am up here in Idaho so it does get cold!
I am aware of the low point drains on the Forest River products but I am not aware of any on my Lance trailer that I am getting rid of. Thanks for the advice and your time to reply. I may upgrade to a 6 gallon compressor only because it is a good opportunity to upgrade what I have!
10-09-2014, 06:52 PM
I do the same deal, no air just A/F.
Takes about 20 min by myself.
10-09-2014, 08:01 PM
Others will disagree, but I don't trust blowing the water out of the lines method. My fear is that water will somehow find a low spot at a tee fitting or something. My fear is the air will blow right by the low spot allowing the water to freeze over the winter.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
10-09-2014, 08:37 PM
I'm a pink stuff fan. My buddy with a Four Winds he's had forever only uses air and an auto tire dc air compressor.
2017 GMC Yukon
2018 Roo 23 ikss
10-09-2014, 08:42 PM
r u need is one that you pump up your tire that what I use
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
10-09-2014, 08:53 PM
New FR Owner
crunchman
+1
Semper Paratus
USCG, Disabled
2015 Grey Wolf 17BH
2001 Ford 4x4 F-250 Crew
10-09-2014, 08:55 PM
It sounds like their three camps. Those who use air only, those who use the "pink stuff" and those who use both. My plan was to use air followed by pumping antifreeze.
10-09-2014, 09:26 PM
Wow, great info in here! I've always had my lines blown out by someone else because I never thought my puny 1-gallon compressor was big enough....I assumed you needed one of those huge ones.
And I'm one of those red antifreeze guys, too....it can get 20-below here at 7,000 in the Rockies so don't ever want frozen lines. It does rinse out real well...just put a little bleach into the water in the Spring when rinsing it all out.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
10-09-2014, 09:36 PM
Just make sure to allow the air press to build up between blowing each faucet. Use 30-35 psi at the compressor. Blow from top, shower and sinks down to outside shower and drains. Leave drains open on completion.
10-10-2014, 08:47 AM
Blow all my lines out first and then pump in antifreeze.
